1eightySX Posted September 15, 2010 Author Report Share Posted September 15, 2010 So I am missing the throttle quadrant. Guess I will need to find one of those. Quote Link to comment
ggzilla Posted September 15, 2010 Report Share Posted September 15, 2010 Well you don't have to have one like that. I actually ran it just like you see in the photo, with a simple u-shaped piece of sheet to link the weber to the datsun cable end. And redline weber sells more fancy types. Quote Link to comment
1eightySX Posted September 15, 2010 Author Report Share Posted September 15, 2010 #1 Appears to be your gas tank vent that usually runs to an evap canister. [/img] What does that look like exactly? this whole evap canister is going over my head. EGR signal vacuum hose goes next to this hose. Where might this be? Sorry for all the dumb question... however I have learned more in the last 5 minutes then I have searching the net for the last two days! Quote Link to comment
ggzilla Posted September 15, 2010 Report Share Posted September 15, 2010 Just plug all the open holes -- don't worry about the EGR. The engine will run good. Do not plug the fuel tank vent line. Just attach to a filter so a spark doesn't blow you to king and come. It goes like this: For more information see B210 Carbon Canister Quote Link to comment
1eightySX Posted September 15, 2010 Author Report Share Posted September 15, 2010 Cool, now I got some things to do. It will have to wait a bit as this weekend I am off to DMCC. I hope it doesn't get too cold here too quick.... we had an awful summer. Any way this thread has been super helpful. I am sure I will ask more questions later on but that is enough to take in for now. This car is going to be a bit of project at least I didn't have to pay for it. I hope i can get in running, then I can address the other issues. Quote Link to comment
Migi Posted September 15, 2010 Report Share Posted September 15, 2010 Yes, "Tire Factory" stores here carry Nokian tires. Hakkapilitta 7? Hakkapilitta 5 is only avaiable now. I was thinking of Hakkapilitta RSi, since we do not get much ice here. http://www.nokiantyr...Hakkapeliitta+7 Sorry mods.. this is last tyre post in this topic.. skib please dont get me banned.. Quote Link to comment
1eightySX Posted October 18, 2010 Author Report Share Posted October 18, 2010 Ok, so I took some more pics and have some questions. Perhaps a review. (Pics aren't as nice this time) It just occurred to me that the hose should maybe be on the lower portion and not the upper portion. Is that correct? Hopefully I understood this from earlier instructions. Does that seem almost right? Sometimes I really just guess a bit. Which numbers go to which letters? Again, any help would be greatly appreciated. I am sure things need to be changed and I have some time off on Friday to take a crack at it. Quote Link to comment
metalmonkey47 Posted October 18, 2010 Report Share Posted October 18, 2010 (edited) ooooooooooooo this is a difficult one.... hmmmm... let me see if I can find some info... Edit: Turns out the Datsun1200 wiki is empty on this info. I'll let GGZilla take a shot at this. Edited October 18, 2010 by metalmonkey47 Quote Link to comment
1eightySX Posted October 19, 2010 Author Report Share Posted October 19, 2010 Ok well thanks for the effort. If anybody knows let me know.:) Quote Link to comment
ggzilla Posted October 20, 2010 Report Share Posted October 20, 2010 Yes, for a 1978 B210 Sedan: 1 to smaller line 2 to larger line 3 to C vapor vent line Quote Link to comment
ggzilla Posted October 20, 2010 Report Share Posted October 20, 2010 The middle connector on the charcoal canister is the purge line. It connects to the Vacuum fitting on the manifold. The small line going to the canister is the signal line. It tees into the distributor vacuum line. Don't let the EGR line come in contact with the exhaust manifold. This is a common cause of vacuum leaks (burnt hoses). Quote Link to comment
1eightySX Posted October 23, 2010 Author Report Share Posted October 23, 2010 So I hooked it all up and it runs, but it is not pulling fuel from the gas tank. If we pour Fuel directly into the carb while it is turning over it will run through that fuel just fine. I will look at the fuel filter, and maybe consider a new fuel pump. If I need to order a new ones any recommendation of where I should do it? Quote Link to comment
RadioRedline Posted October 23, 2010 Report Share Posted October 23, 2010 So I hooked it all up and it runs, but it is not pulling fuel from the gas tank. If we pour Fuel directly into the carb while it is turning over it will run through that fuel just fine. I will look at the fuel filter, and maybe consider a new fuel pump. If I need to order a new ones any recommendation of where I should do it? I am so happy right now! I Found that car on usedregina and the loser PO who was about 10 mins away from dropping some ford v8 into it! Hes the same PO who unhooked your gas tank, and threw out the Carb! Your B210 will be good to you now boy! You got it running, and saved it from getting Forded. I can honestly say, I have NEVER been stranded by a Datsun. (my 83 Nissan 4x4 did once lol) I wasn't really 'needing' another car when I bought that thing, but I was like: "Datsun?!#$%^&....IT MUST BE SAVED!" Radio Quote Link to comment
ggzilla Posted October 23, 2010 Report Share Posted October 23, 2010 it is not pulling fuel from the gas tank. If we pour Fuel directly into the carb while it is turning over it will run through that fuel just fine. This is a common issue with cars of all makes. The cause might be: * Fuel filter * Fuel pump * Fuel lines * Carburetor: accelerator pump or choke First check the float level. On the carb is the sight glass window. If the fuel comes halfway up the glass, the fuel supply is OK. If the fuel comes halfway up the glass, the problem is internal to the carb. Remove the air cleaner and verify the choke is closing. On the A-series, the engines won't start in cold temps if the choke doesn't close. Quote Link to comment
1eightySX Posted October 23, 2010 Author Report Share Posted October 23, 2010 I am not out of the woods yet Radio, but I will get there. It was encouraging to hear the motor run, it was really loud and I have no exhaust on it. :) Hopefully I get this all figured out. I think I will change the Filter First. Any idea where to buy one? Do most automotive stores carry them? Quote Link to comment
RadioRedline Posted October 23, 2010 Report Share Posted October 23, 2010 HEY! I think I have the Haynes manual for your car. I got it afterwards, from a lot I purchased on usedregina. Let me make sure its the right gen. And I realize that its not perfect yet, but you shoulda seen it without the fenders and hood on when I got it it was 100% apart lol. Radio Quote Link to comment
ggzilla Posted October 23, 2010 Report Share Posted October 23, 2010 Yes you can find them at any auto parts store. Quote Link to comment
RadioRedline Posted October 23, 2010 Report Share Posted October 23, 2010 Fuel Filter you can get at Canadian Tire. or Auto Parts plus or Partsource. Radio Quote Link to comment
RadioRedline Posted October 23, 2010 Report Share Posted October 23, 2010 Oops nvm its the new Gen 79+ Radio Quote Link to comment
1eightySX Posted October 26, 2010 Author Report Share Posted October 26, 2010 Amazon supplied me with a manual should be here soonish. Quote Link to comment
az_rat210 Posted October 27, 2010 Report Share Posted October 27, 2010 Here are some photos of my weber installed on an A-15 This is showing the Charcoal Canister. The small inlet you can get activation vacuum by T-Connecting with Distributor Vacuum. These are of Weber Vacuum connections. The forward one is distributor vacuum, the one back of it is for EGR. This is my linkage setup. Just reverse the stock hitachi Linkage, flip it upside down, you can hook up the cable. You will note mine is missing a bottom portion because I cut it off. The bracket came with the Carb from Redline. Quote Link to comment
