Grahem Posted September 7, 2010 Report Share Posted September 7, 2010 Hey i recently picked up a factory brown dash and interior from a 79 datsun motorhome with 62,000 org Km's, the dash is in very good condition with only 2 small marks near the steering column, im just wondring how rare is it and approx what its it worth? it does not have a tach or clock and the delete panel is gone it has an 80's tape deck Quote Link to comment
datsunaholic Posted September 7, 2010 Report Share Posted September 7, 2010 Rare enough. It was a one-year item ('79) and far less than half that year had them. Can't give a value... Worth what you can get for it. Quote Link to comment
datzenmike Posted September 8, 2010 Report Share Posted September 8, 2010 That Jim Paxton's dash? Quote Link to comment
danfiveten Posted September 8, 2010 Report Share Posted September 8, 2010 I always preferred black dashes. I hated the blue dash in the 720 so much, i spray painted it black >.< Quote Link to comment
Grahem Posted September 8, 2010 Author Report Share Posted September 8, 2010 yea i got it off jim in sooke Quote Link to comment
datzenmike Posted September 8, 2010 Report Share Posted September 8, 2010 Gees Grahem, I have two 710s now. What have you done to me??? Quote Link to comment
Bleach Posted September 8, 2010 Report Share Posted September 8, 2010 They are rare but I have not yet heard of someone wanting one vs a black dash. In the z-cars, the brown dash will typically be in a better shape because the color doesn't soak up the heat as much. Black gets hot and cracks. Quote Link to comment
mike Posted September 8, 2010 Report Share Posted September 8, 2010 You can re-dye/paint them, I have done this to black dashes as the color always turns grayish. Look around the back side towards the windshield and see if there are any hairline cracks starting. If there are any present take a small drill bit and make a hole at the very end (beginning) of the crack. Then seal/patch it with a high quality adhesive sealant (really sticky stretchy caulk) I use NP1 and it seems almost exactly the same as greatstuff gasket sealant but it is a quarter of the cost... it sticks to everything and it has a 300% stretch rate when it is dry. To clean it up use denatured alcohol. I used SEM semigloss/satin bumper black to paint mine as it is made for vinyl/plastics, it is flexable and it doesnt have a high sheen. I also painted it in the sun so that everything was expanded/pliable when the paint was applied I did this to the dash in my KC and it still looks perfect after 2 1/2 years... Pricewise, color of the dash should only matter if it is ABSOLUTELY perfect... If you bolt one in without checking for small cracks it will probably be broken/cracked in a year. In the condition of yours (unsure about the two small marks without pics... are they smudges or cracked broken areas?) Id feel comfortable asking around $150, if theyre cracks... about half that. Good dashes are a bitch to find and asking a little more will ensure that it doesnt go to someone who will put it in their rusbucket and have it end up in a wrecking yard 6 months down the road. Quote Link to comment
Grahem Posted September 14, 2010 Author Report Share Posted September 14, 2010 Datzenmike- so what are the details on your new car? are you going to add pictures to your other thread? Thanks For the info on the dash i will have to go over it and check for any signs of cracks, then decide what im going to do to it. Quote Link to comment
datzenmike Posted September 14, 2010 Report Share Posted September 14, 2010 Hey Grahem. Here's my build/project thread: http://community.ratsun.net/topic/24412-new-goon-owner/ Quote Link to comment
