thisismatt Posted December 21, 2016 Report Share Posted December 21, 2016 I need one for my 521. Stock wheel and 34"+ inseam makes it hard to get past the wheel :p Quote Link to comment
Josh K. Posted December 21, 2016 Author Report Share Posted December 21, 2016 I'm going to try and space the column down about a 1/4". The wheel is in the perfect position depth wise and the diameter is spot on. The old wheel was a joke :) Quote Link to comment
Josh K. Posted December 21, 2016 Author Report Share Posted December 21, 2016 So this is super late, as always for me, but the Toyo r888 runs suuuper wide in the tread department. They're 225/45/15 fits on a j10 with surprisingly minimal stretch. They also offer a 235/50 for a bit more chunky profile. Hope this helps!! I wish Toyo made a 235/45. That would be perfect! Here's the Maxxis RC1. I'm assuming the VR1 will be the same when released. And the Toyo. Quote Link to comment
datsunfreak Posted December 22, 2016 Report Share Posted December 22, 2016 I'm going to try and space the column down about a 1/4". Did this on one of my 510s. It is a little easier if you loosen the bolts holding the steering box to the frame first. ;) 1 Quote Link to comment
Duke Posted December 23, 2016 Report Share Posted December 23, 2016 Did this on one of my 510s. It is a little easier if you loosen the bolts holding the steering box to the frame first. Shouldn't matter on later cars. All 510's after 68 have a U joint between the steering box and the firewall. I have lowered my column as well. Definitely helps with the driving position. 1 Quote Link to comment
datsunfreak Posted December 23, 2016 Report Share Posted December 23, 2016 Shouldn't matter on later cars. All 510's after 68 have a U joint between the steering box and the firewall. Oh right. Mine was a '68. :rofl: :rofl: :rofl: Apropos of nothing, some of the RHD cars are not this way. Most have fixed columns. 1 Quote Link to comment
Josh K. Posted December 24, 2016 Author Report Share Posted December 24, 2016 Thanks guys. Putting in work. Decided to replace the rear shelf with new sheet metal. I'll also cover the area where the backseat went. Finishing up loose ends. 3 Quote Link to comment
that one guy Posted December 25, 2016 Report Share Posted December 25, 2016 Very nice looking work as always! That's good info on those Maxxis tyres, didn't even know they made 15's... when should you have an answer on the VR1's, and any possibility for a potential group buy? 1 Quote Link to comment
Josh K. Posted December 27, 2016 Author Report Share Posted December 27, 2016 Very nice looking work as always! That's good info on those Maxxis tyres, didn't even know they made 15's... when should you have an answer on the VR1's, and any possibility for a potential group buy? I bet there is on a Miata forum. I'll look around. I'm sticking to my plan to get the car "road worthy" by Jan 3rd. Just need to weld out the wheel "tub" tomorrow and then I can focus on finishing the metal work on the passenger quarter panel and welding to the car. I'm hoping to do all that tomorrow. Corner reconstructed and done. 5 Quote Link to comment
Josh K. Posted January 30, 2017 Author Report Share Posted January 30, 2017 I took a month off... I got burnt out. Lot's of travel for work. I found my way to the garage today.... Welded the passenger quarter onto the car!! It won't come off again! Now I need to get the driver side attached and then the trunk pan. Then I can finish the quarter drops and tidy up some details before installing the tail light panel... Canby, Canby, Canby... 8 Quote Link to comment
q-tip Posted January 30, 2017 Report Share Posted January 30, 2017 Good thing you got some stuff done, I was about to bump this threat and make sure you are still alive. :Lol: 3 Quote Link to comment
Draker Posted January 30, 2017 Report Share Posted January 30, 2017 Every day a little closer! 1 Quote Link to comment
tr8er Posted January 30, 2017 Report Share Posted January 30, 2017 Yeah. I was wondering. Stoked to see the ball picked up 1 Quote Link to comment
Josh K. Posted January 31, 2017 Author Report Share Posted January 31, 2017 I hate sheet metal work. It's gotta be done though :( Quote Link to comment
Josh K. Posted February 1, 2017 Author Report Share Posted February 1, 2017 Got my collector plate today. Yummy, yummy. 7 Quote Link to comment
Josh K. Posted February 1, 2017 Author Report Share Posted February 1, 2017 Transferring the bolt pattern. If anyone knows where to get the metal panel clips and screws I'd appreciate it. 4 Quote Link to comment
Draker Posted February 1, 2017 Report Share Posted February 1, 2017 That looks great!! 1 Quote Link to comment
Josh K. Posted February 1, 2017 Author Report Share Posted February 1, 2017 I'm excited ;) Quote Link to comment
mklotz70 Posted February 1, 2017 Report Share Posted February 1, 2017 Have you googled to find the trim clips? Tons showed up when I just did it. I was going to send a link or two, but I have no clue what style you're looking for. Once you google them, click on images to sort through them. :) Quote Link to comment
Josh K. Posted February 1, 2017 Author Report Share Posted February 1, 2017 I haven't. I guess I should measure the thickness and look on McMaster Carr.. :) Quote Link to comment
q-tip Posted February 1, 2017 Report Share Posted February 1, 2017 Mmmmmm center garnish.... 1 Quote Link to comment
Duke Posted February 2, 2017 Report Share Posted February 2, 2017 I haven't. I guess I should measure the thickness and look on McMaster Carr.. :) Also check out www.belmetric.com. They have a bunch of different body fasteners...and they are all metric! 2 Quote Link to comment
Josh K. Posted February 2, 2017 Author Report Share Posted February 2, 2017 Also check out www.belmetric.com. They have a bunch of different body fasteners...and they are all metric! Good idea! I love Belmetric! Quote Link to comment
Josh K. Posted February 2, 2017 Author Report Share Posted February 2, 2017 Done! 1 Quote Link to comment
Icehouse Posted February 3, 2017 Report Share Posted February 3, 2017 Make sure you use super short screws or you will put out dents in the garnish. Don't ask me how I found this out. 1 Quote Link to comment
