Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
Josh K.
  • Replies 2.5k
  • 3 weeks later...
No go on the 205/45-15, it's discontinued. I'm sticking with the 205/50-15. There is some rumblings about Rota making a 15x9 0 Offset in the Grid-V, hopefully this happens before my car is finished and I can run these on the back. Per the Australian rep the mold hasn't been made yet so not much hope, I can dream though?.....
So I'm thinking about going with Dodge Omni flares front and rear. Any thoughts on this?
Edited by Josh K.
195/45R15 - 22 Tall - 7.7 Wide
205/45R15 - 22.2 Tall - 8.2 Wide
205/50R15 - 23.1 Tall - 8.31 Wide
It looks like Toyo makes a 205/45-15. This is what I'll try next! That will keep me at the 22" range with the extra tread width!
Hey Josh Check out these tires they are a real sticky tire I have run them on my buddys S2000 that I codrove last year and they are very well priced
http://www.tirerack.com/tires/tires.jsp?tireMake=Hankook&tireModel=Ventus+R-S3&partnum=245WR5Z222&vehicleSearch=false&fromCompare1=yes
http://www.tirerack....romCompare1=yes
Those look real nice!
I called my local guy and he can't get the Ventus direct, he would have to order from tire rack and they would be $175 shipped.
I found the RA1's come in 225/45-15, he's checking on those for me. I have had a lot of success with the RA1's so I'm crossing my fingers!
225/45R15 - 22.9 Tall - 9 Wide
Thanks!
Josh-
No RA1's in 225, checking into R1R's now.....
So back to making progress.
Today I spent a little time on the throttle body. I decided to remove the heat pipe and paint it.
Edited by Josh K.
Assembled.Now I just need to clean up the fuel rail and possibly rotate the FPR and the intake is done!!! I would also like to get a different TPS as mine has the harness out the back and the ugly spare plug in the front, Auto tranny version?
Edited by Josh K.
My KA TPS has the same thing .. . . . I was worried I needed that plug,,, ,, :cool: ...... .. is your KA out of a S13???
What did you do about the butterfly valve on the upper intake mani?????
I pulled the shaft and welded the end holes, I didn't worry about the ones between the runners.
Here's what I found on the TPS. It appears mine is the S13 Auto.
Here:
Here's what I want, S13 Manual:
Here's the S14 Version:
Edited by Josh K.
Went to the junk yard today and no Dodge Omni's in site. I did find a whole lot of early Golf's. Tomorrow I'm gonna swing by and pick up a fender to hack up. If it works then I'll grab the rest at $35 a piece http://community.ratsun.net/public/style_emoticons/default/wink.gif
I decided to take some more pics of the manifold setup today because I like seeing my work in photos......
Edited by Josh K.
So I went to the pull a part and got me a VW Golf fender to cut up. After I cut the flare out and held it up to the car I thought no way in hell. After arrange it about 10 times I'm now in love!
I definitely need at-least a 1/2" spacer, I'm also most likely going to the 225's which will help fill out the flare http://community.ratsun.net/public/style_emoticons/default/cool.gif
Donor fender.
The goods! I have a lot of work ahead but I'm game!
Edited by Josh K.
Thanks for the heads up. I actually like the depth of the golf flares better then the Omni's. They also have metal around the flare I can use to fill the gap left from where they hacked out for the bubble flares.
I'm gonna try and fit the front tomorrow. I hacked too much off this one. Im hoping it will work for the front.
Thanks Fuzz. It wasn't my intention going in to fix a ton of stuff... But, I was always taught if your gonna do it, do it right!
My buddy Elton donated his busted up fender for mock up on the front, looks like the first flare I cut up can be used.
image.jpeg.088e02f720ba1bee88ca66f1eee7e007.jpeg\
I made huge progress in another area. getting the 220v setup for the welder. Gonna borrow my bro's Miller MIG so I can start stitching this thing back together http://community.ratsun.net/public/style_emoticons/default/blink.gif
Edited by Josh K.
  • Josh K. changed the title to Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
