thisismatt Posted July 14, 2018 Report Share Posted July 14, 2018 Nice lights ? Could weld up a flat bar hoop from the cross member around the oil filter & pan...maybe knife edge it for quick work of fuzzy animals ? 1 Quote Link to comment
Josh K. Posted July 14, 2018 Author Report Share Posted July 14, 2018 14 minutes ago, thisismatt said: Nice lights ? Could weld up a flat bar hoop from the cross member around the oil filter & pan...maybe knife edge it for quick work of fuzzy animals ? That would be cool ? ? Quote Link to comment
Josh K. Posted July 14, 2018 Author Report Share Posted July 14, 2018 Working on shrinking down the heat shield... 4 Quote Link to comment
thisismatt Posted July 14, 2018 Report Share Posted July 14, 2018 Your strut nuts must be Australian 1 Quote Link to comment
Josh K. Posted July 14, 2018 Author Report Share Posted July 14, 2018 2 minutes ago, thisismatt said: Your strut nuts must be Australian You don't miss anything do you? They're serrated nuts so I gotta put some washers beneath them or they'll auger the paint ?? just haven't gotten around to it ? Quote Link to comment
thisismatt Posted July 14, 2018 Report Share Posted July 14, 2018 I'm a noticer, that's why I'm always fixing everyone else's crap at work :P I knew that, just giving you crap. Lookin good 1 Quote Link to comment
mrbigtanker Posted July 14, 2018 Report Share Posted July 14, 2018 1 hour ago, Josh K. said: You don't miss anything do you? They're serrated nuts so I gotta put some washers beneath them or they'll auger the paint ?? just haven't gotten around to it ? Just curious what about bubble top allen head bolts going down and nuts underneath. Quote Link to comment
datsunfreak Posted July 16, 2018 Report Share Posted July 16, 2018 On 7/14/2018 at 12:57 AM, mrbigtanker said: Just curious what about bubble top allen head bolts going down and nuts underneath. That's how I did mine on the 510. Looks a lot better in my opinion... 1 Quote Link to comment
Josh K. Posted July 21, 2018 Author Report Share Posted July 21, 2018 (edited) Sounds like a pita.. I just need some washers ?? Still working on it.. Put on some trim, assembled quarter windows with new rubber, planned out the rest of the wiring and ordered a circuit breaker. Headliner goes in Thursday and then the car goes back together. Should be on the road in the next few weeks. Had to stop and clean the shop... couldn't walk anymore... All clean!!! Edited July 21, 2018 by Josh K. 4 Quote Link to comment
datsunfreak Posted July 21, 2018 Report Share Posted July 21, 2018 18 hours ago, Josh K. said: Sounds like a pita.. Well, I have long arms, so... ? 1 Quote Link to comment
Josh K. Posted July 22, 2018 Author Report Share Posted July 22, 2018 I'll just leave this here...... ???? 6 Quote Link to comment
Josh K. Posted July 22, 2018 Author Report Share Posted July 22, 2018 (edited) Door still needs adjustment. I'm a sucker for door alignment... It's a bitch to hang and align doors with new rubber... Edited July 22, 2018 by Josh K. 1 Quote Link to comment
mrbigtanker Posted July 22, 2018 Report Share Posted July 22, 2018 Wow just fuckin Wow. Beautiful man just beautiful. 1 1 Quote Link to comment
Josh K. Posted July 22, 2018 Author Report Share Posted July 22, 2018 (edited) 8 hours ago, mrbigtanker said: Wow just fuckin Wow. Beautiful man just beautiful. Thanks! I'm stoked!! I had to spin the car around in the garage so I had more room. Good time to get some pics of the sun hitting it... Edited July 23, 2018 by Josh K. 4 Quote Link to comment
mklotz70 Posted July 22, 2018 Report Share Posted July 22, 2018 Absolutely amazing!!! 2 Quote Link to comment
Josh K. Posted July 23, 2018 Author Report Share Posted July 23, 2018 Thanks!!! Dirty work Sunday. Had to weld up all the holes in the floor and rust coat the floor and wheel tubs. Now I just need to seam seal the tubs to the qaurters. Getting closer. I ordered 50sqft of Rockmat to deaden the floors, back seat area and trunk pan. Also got DynaLiner foam for the front floors to give it that extra quiet and cush feel ?? I have to wash the car real good first so I can check for leaks. You don't want leaks under the sound deadener.. then I'll put it all down and have carpets made... I used Rust Bullet to seal the floors and tubs. I usually use Por15 but this is cheaper and better. 6 Quote Link to comment
Josh K. Posted July 26, 2018 Author Report Share Posted July 26, 2018 Sometimes you gotta pay the pros. In this case it was worth every penny ?? Front and rear windows go in tonight!! 4 Quote Link to comment
Josh K. Posted July 26, 2018 Author Report Share Posted July 26, 2018 My interior guy is gonna wrap the dash pad in Suede to match my Suede Sparco steering wheel.. and then he'll make a full carpet set that wraps up to the back window along with floor mats. Soon... 2 Quote Link to comment
Josh K. Posted July 27, 2018 Author Report Share Posted July 27, 2018 My FTP server is down. Pics will be back.. 1 Quote Link to comment
Josh K. Posted July 29, 2018 Author Report Share Posted July 29, 2018 (edited) Back to the grind! Stainless window trim is in and now I'm working on prepping the dash to go back in. I decided to add a circuit breaker inline with a key locked cutoff switch in the dash (the AGM battery can't have a draw and it adds another layer of security). all I really have to do for wiring is make new main power and ground cables and wiring in the trunk. So today is a big day.. maybe it will fire off?? Edited July 29, 2018 by Josh K. 5 Quote Link to comment
]2eDeYe Posted July 29, 2018 Report Share Posted July 29, 2018 Nice use of existing infrastructure ? 1 1 Quote Link to comment
Josh K. Posted July 29, 2018 Author Report Share Posted July 29, 2018 1 hour ago, ]2eDeYe said: Nice use of existing infrastructure ? ?? 1 Quote Link to comment
Josh K. Posted August 1, 2018 Author Report Share Posted August 1, 2018 Drove the dime to the gas station. As soon as I pulled in a guy pulled up next to me and asked how much to buy it ?? I told him you can't afford it.. he said how much.. I said 45-50k.. he said I can afford it.. I said too bad ?? I laid some rubber on the way out for him ?? 7 Quote Link to comment
five1oh Posted August 2, 2018 Report Share Posted August 2, 2018 1 hour ago, Josh K. said: Drove the dime to the gas station. As soon as I pulled in a guy pulled up next to me and asked how much to buy it ?? I told him you can't afford it.. he said how much.. I said 45-50k.. he said I can afford it.. I said too bad ?? I laid some rubber on the way out for him ?? Awesome! There's a line forming on mine as well ??? 1 Quote Link to comment
