OEM Cam Specs?
Radim
  • Replies 9
L20B:
Lobe lift 0.276"
Lift at valve 0.413"
Duration 248 degrees
Everybody measures it differently but here's the valve opening and closing sequence for the L20B cam starting at TDC compression stroke:
at 126 ATDC (or 54 degrees BBDC) exhaust opens.
at 344 degrees (or 16 degrees BTDC) intake opens
at 374 degrees (or 14 degrees ATDC) exhaust closes.
at 592 degrees (or 52 degrees ABDC) intake closes compression stroke continues for another 128 degrees to TDC or a total of 720 degrees or two full turns.
Valve overlap (intake and exhaust open together) 30 degrees
Naturally the valves only begin to open/close at these points in theory. Actually the valve clearance delays the opening and closes them early
  • 2 years later...
