dato Posted August 31, 2010 Report Posted August 31, 2010 so i got a call from my uncle that drives the 210 and he says the carb has gone bad on the it and the idle speed had to be turned all the way up to keep the thing running :( please if anyone can help me i need a new carburetor for it!!! i don't want to lose another datsun!!! :(
dato Posted August 31, 2010 Author Report Posted August 31, 2010 Need one of these ASAP!!! please let me know if you have one and how much you want for it
TAG Posted September 1, 2010 Report Posted September 1, 2010 so i got a call from my uncle that drives the 210 and he says the carb has gone bad on the it and the idle speed had to be turned all the way up to keep the thing running :( please if anyone can help me i need a new carburetor for it!!! i don't want to lose another datsun!!! :( How about a Weber dual throat downdraft. I put one on my 210; it made a huge difference. I would give you the old one, but it's shot!
dato Posted September 1, 2010 Author Report Posted September 1, 2010 How about a Weber dual throat downdraft. I put one on my 210; it made a huge difference. I would give you the old one, but it's shot! yeah i would love to get a webber but money is super tight right now :hmm:
metalmonkey47 Posted September 1, 2010 Report Posted September 1, 2010 Got a rebuilt one from an A15 for 30+shipping with air cleaner. Needs choke parts, but been recently rebuilt.
dato Posted September 1, 2010 Author Report Posted September 1, 2010 Got a rebuilt one from an A15 for 30+shipping with air cleaner. Needs choke parts, but been recently rebuilt. Awesome!!! how hard are choke parts to get? is a money order ok btw? Thanks!!!!
metalmonkey47 Posted September 1, 2010 Report Posted September 1, 2010 Not entirely sure on the choke pieces. It's an electric choke that just needs to be set up and needs a new cap, or you can convert it to manual choke :P Money order is fine. I'll get a shipping quote asap.
ggzilla Posted September 1, 2010 Report Posted September 1, 2010 Most likely he doesn't need a new carb. Whenever there are running problems, people simply turn up the idle What's needed is to fix the real problem. It could be as simple as a loose connection for the idle-cut solenoid. Don't get another carb. Save yourself some bucks, and figure out what is wrong.
dato Posted September 2, 2010 Author Report Posted September 2, 2010 Most likely he doesn't need a new carb. Whenever there are running problems, people simply turn up the idle What's needed is to fix the real problem. It could be as simple as a loose connection for the idle-cut solenoid. Don't get another carb. Save yourself some bucks, and figure out what is wrong. yeah thats what i thought too but the mechanic said all the seals in the carb are pretty much shot
dato Posted September 2, 2010 Author Report Posted September 2, 2010 Not entirely sure on the choke pieces. It's an electric choke that just needs to be set up and needs a new cap, or you can convert it to manual choke :P Money order is fine. I'll get a shipping quote asap. cool!, thank you :cool:
datzenmike Posted September 2, 2010 Report Posted September 2, 2010 Two posts on the same subject is very confusing. I merged both.
ggzilla Posted September 3, 2010 Report Posted September 3, 2010 There are no "seals" to cause a bad idle. There is only 3 gaskets. I have never seen the middle gasket go bad. A new kit, with all three gaskets is only $20.
metalmonkey47 Posted September 3, 2010 Report Posted September 3, 2010 (edited) Don't get another carb. Save yourself some bucks, and figure out what is wrong. X2! Make sure the problem is the carb before buying. I don't wanna sell you something you don't need. You may just want to rebuild it. You can generally get kits for around $30. If you do decide that the carb is bad and needs to be replaced, PM me and we can go from there. Edited September 3, 2010 by metalmonkey47
ggzilla Posted September 3, 2010 Report Posted September 3, 2010 hey dato, where's your uncle live? Maybe we could go there this weekend and get it running better, or at least looke at it. PM me.
dato Posted September 3, 2010 Author Report Posted September 3, 2010 hey dato, where's your uncle live? Maybe we could go there this weekend and get it running better, or at least looke at it. PM me. he lives out in edmonds
ggzilla Posted September 3, 2010 Report Posted September 3, 2010 I'm heading out to Pull-A-Part this weekend...we could meet up Sat, Sun or Monday. Also hoping to go to the Arlington PaP.
