Weber DGAV 32/36
  • Replies 10
Yes, but it needs a different adapter plate.
You can take the stock A14 carb cable bracket and bolt it on the Weber. Then the only thing needed is to make a throttle cable hold down bracket.
DGAV is water heated choke. But you can unbolt that and bolt the A14 electric choke on the Weber.
  • 5 months later...
