red-521 Posted August 29, 2010 Report Share Posted August 29, 2010 Hi there, new to posting here, but have gotten a lot of useful info. on other issues...so I thought I'd give this a go to get an answer. I am replacing a rear main seal on my 71 - 521 truck and I ned to drop the oil pan to get at the bearing to remove it. I have the transmission off as well as the clutch and flywheel. The front cross member has a bottom part that is connected by two bolts on each side. Can I just remove this without lifting the engine to get the oil pan off? The engine seems to mount to the frame and this bar at the bottom doesnt appear to be doing much but stabalize the flex in the frame? Anybody done this without jacking the engine? Quote Link to comment
datzenmike Posted August 29, 2010 Report Share Posted August 29, 2010 The cross brace can be removed for pan access. It's really for torsion bar support so you do need it, it just doesn't hold the motor in or anything. Quote Link to comment
pharouh Posted September 5, 2010 Report Share Posted September 5, 2010 Ditto. You may need a steel rod of some kind to line it back up after you remove it to get the bolts back in. I've done it twice. it's not bad. Take the crossmember out,unbolt and lower the idler arm on the passenger side. Quote Link to comment
izzo Posted September 5, 2010 Report Share Posted September 5, 2010 If all else fails, sawzall :rofl: Quote Link to comment
little beast Posted September 5, 2010 Report Share Posted September 5, 2010 Ditto. You may need a steel rod of some kind to line it back up after you remove it to get the bolts back in. I've done it twice. it's not bad. Take the crossmember out,unbolt and lower the idler arm on the passenger side. Quote Link to comment
little beast Posted September 5, 2010 Report Share Posted September 5, 2010 pharouh im looking for a smaller versoin of the front airdam shown on the front of your truck for my 521 can u point me in the rite direction? Quote Link to comment
pharouh Posted September 5, 2010 Report Share Posted September 5, 2010 pharouh im looking for a smaller versoin of the front airdam shown on the front of your truck for my 521 can u point me in the rite direction? sorry,man I have no idea where you would get one. The only truck airdams I've seen are for 620s and you get them here. I remember seeing a 521 airdam years ago,but nothing since then. They were made from a flexible black plastic like car bumpers. Good luck! Quote Link to comment
red-521 Posted September 6, 2010 Author Report Share Posted September 6, 2010 The cross brace can be removed for pan access. It's really for torsion bar support so you do need it, it just doesn't hold the motor in or anything. Hey thanks everything worked out pretty easy. Quote Link to comment
