LeX Posted August 29, 2010 Report Share Posted August 29, 2010 LINKS TO VIDEOS: For sale 1972 datsun 510 wagon sr20det $5000 as it sits motor has blowby but still runs. Needs rebuild before driveable. Dynoed 284whp with exhaust leaks and undersized intercooler piping. Since dyno, intercooler piping been upgraded and leaks corrected. Easy 300+ at safe boost level Car does need a little bit of bodywork but frame rails and body are solid. Interior is complete and good but not perfect. sr20det motorset S30 front seats autometer boost gauge (to be hooked up) pretty new battery rota RB 15x7 15x8 wheels with fuzion ZRi tires 3" turboback exhaust with flex section and magnaflow clone muffler Forced Performance 20g turbocharger external wastegate @ 1 bar boost w/ dump pipe Evo8 FMIC greddy oil filter relocation NOS Koni Inserts (front) cut 250lb coilover springs (front) rear is stock with 1" blocks. Included in sale are 2" blocks and sensatrac shocks w/ helper springs custom FMIC piping T2/T3 adapter for turbocharger Deatschworks 550cc injectors K&N intake Z32 maf 5spd transmission high flow bosch fuel pump custom driveshaft XTD stage 3 clutch 240sx throttle cable adapter for speedo so it works but not accurate ECU tune by Jason@emance. car professionally wired up (not a hack job) Summit alumium racing radiator new belts and hoses where applicable NOS rubber motor isolators / custom mounts custom welded and flipped front crossmember custom transmission crossmember with rubber inserts. heat has been bypassed but can work. No AC hardware Battery relocation to back seat enlarged shifter hole and transmission tunnel relocated new fuel lines relocated proportioning valve and driver side brake lines Link to comment
