Tacomaboy Posted August 27, 2010 Report Share Posted August 27, 2010 For sale is my very reliable and equealy good looking R-16 which can be seen on my first posts. I put over 2200 mi on this combo through the summer with zero problems. The engine has fresh seals and gaskets through out. New timing chain set ,tersioner and steel backed guides,new heavy duty head gasket from Dean's,-.005 on mating surface. cut and grinde on valves and seats,new thermostat housing and timing cover studs. Not to mention a S load of time. The trans as well has fresh gaskets,o-ring 's and seals thrugh out. New clutch pressure plate,release brg,re-surfaced flywheel. Nothing was left to chance. Also included in this package is the matching radiator which also has beed flushed,pressure tested and painted. Buyer will get engine,matching 4 spd. trans,radiator,starter,alternator,clutch slave cyl, all dizzy, vac.lines and fuel lines as well will be included. Buyer should note that the 2nd gear syncro is on it's way out, SU's need either rebuild or further adjustment....... It trys to lay down above 75mph. on days above 90deg. Excelent oil pressure. 45+ cold 25 hot. normal running temp about 125-130. Just a real nice start or complement to ones project. I live about 50 mi south of Seattle. My asking price is quite firm. Thanks for looking Mike. Link to comment
