WTB IR Alternator
  • Replies 10
The only ones I can think of are the 38? amp ones from the '78, '79 and '80 620 and 720 trucks. They are small enough to fit and also clear the idler arm. I tried the 50/60 amp ones from the '81 and on 720 but they are much larger around and don't clear.
I am running a 1979 510 IR alt.......... but my whole wiring harness is from the 79 510 too...... :huh: ........ in my 70 510
The parts store guy showed me a Mitsubishi IR alt that had the same demensions..... even a similar plug....... I think it was a 60amp or 80amp.......... anyone ever tried a Mitsu alt?
I believe the small 720 alternator (35A internal regulated) is the same diameter as the early 510 one (35A external regulated). Hmmm.. I have one of each but they are in the vehicles outside.
Doesn't the 521 have the larger diameter one to start with?
In that case you got it easy. Nearly every Datsun from 1978 into the mid-80s has the regular size alternator. The smaller one is the rare item.
Hitachi LR160/LR150 internally regulated 50A or 60A
Body: about 129mm diameter
Adjuster bolt: about 6-7/8" from mount bolt. The smaller 35A alternator is about 6-1/8".
Is the Saturn a simple bolt-on? Or do you have to do some mild fabrication? I know, read the sticky. The great thing about the Hitachis are they bolt right on and use the same fan belt. And last twenty years.
At least Nissan is still building cars. Saturn factory has shut down. I was going to visit it when I was in Tennessee in June, I called and they said no visits...
I finally got one today, found it at Pull-A-Part for $15
Yes, it is exactly same dimensions as the early 510 & 521 alternator. Use same fan belt & wiring too (but unplug the external regulator)
Alternator (35 AMP model) Nissan 23100-U0100 Hitachi LT-135-13
510 1968-early 1971
521 1969-early 1971
620 1973-1979
1200 1971-1973
Diameter of body: 114mm (4.5") -- larger 50A & 60A Datsun units are 5" diameter
Weight: 8.4 lbs vers 9.6 lbs for the larger one
Alternator (35 AMP model Internal Regulator)
Nissan 23100-B9810 (Mitsubishi A1T22971)
Nissan 23100-B9800 (Hitachi LR135)
Side-by-side comparisons LT135 to LR135
Donor 720 practically only thing left
And the secret wiring for all LR hitachis including the larger 50A and 60A
Store-bought version of jumper wire ($30)
Two jumper wires?
1. The S terminal should be 12V hot when key is turned to IGN
NOTE: on the B310 & 720, S is hot all the time
either way will work
2. The L terminal (Lamp) should be:
* 0V when key is turned OFF
* 12V (more or less) when key is turnd ON
Because the L terminal is the exciter, if your CHG lamp is burned out, the Hitachi LR won't charge.
