Ultramagnus Posted August 4, 2010 Report Share Posted August 4, 2010 This came to mind after my rear disc brake conversion, i replaced a wheel stud that was stripped and what i got from the parts store was shorter it still works but i want to replace them with a longer one. i've been looking at the nismo ones and wondered if it'll fit our hubs? i know about the nismo size diff of the knucles being bigger on the rear will these studs work or is there a replacement from the local parts store? Thanks BTW: i did do a search but i didn't find any topics. Quote Link to comment
Drive510 Posted August 4, 2010 Report Share Posted August 4, 2010 I was wondering the same thing. Tried some rims but studs too short. =( I really don't want to use hub adapters either. Heard they're not safe. Quote Link to comment
Skib Posted August 4, 2010 Report Share Posted August 4, 2010 take it back to the parts store and tell them you want a longer one Quote Link to comment
DISLEXICDIME Posted August 4, 2010 Report Share Posted August 4, 2010 i think the zx rear studs are the long ones Quote Link to comment
Ultramagnus Posted August 4, 2010 Author Report Share Posted August 4, 2010 take it back to the parts store and tell them you want a longer one When i bought the wheel stud, i had the original one w/me. The parts guy the gave me the replacement said the shorter wheel stud was correct and that looking for a diff wheel stud will have issue with the spline being too big or too small. I read that 1997-2005 xterra/frontier might be a little longer i'll have to check this out. Quote Link to comment
Skib Posted August 4, 2010 Report Share Posted August 4, 2010 its parts store guy, you have to tell him what you want, not the other way around. 98% of the time hes a dipshit and has no idea what hes talking about. Quote Link to comment
MikeRL411 Posted August 4, 2010 Report Share Posted August 4, 2010 NISMO catalog part numbers for IRS cars. Pulled from the 510, 610, 710 & 200SX section. 40222-RS025 length 59mm 40222-RS015 length 50mm Thread for wheel nut is M12x1.25 1 Quote Link to comment
Ultramagnus Posted August 4, 2010 Author Report Share Posted August 4, 2010 NISMO catalog part numbers for IRS cars. Pulled from the 510, 610, 710 & 200SX section.40222-RS025 length 59mm 40222-RS015 length 50mm Thread for wheel nut is M12x1.25 So these lug nuts should fit the 510 hubs? There are 2 sizes early 240 s13 had smaller splines all around and s14 rear had a bigger spline but same in the front like s13's. its parts store guy, you have to tell him what you want, not the other way around. 98% of the time hes a dipshit and has no idea what hes talking about. haha true no use in bitchin over $1.50. Quote Link to comment
Dime Dave Posted August 4, 2010 Report Share Posted August 4, 2010 The Dorman #610-320 stud (280ZX rear) is what has been reccomended by some for a longer front stud. 41.5mm v. 32mm for the stock 510 front stud. It turns out this is the stock 510 rear stud as well. Using the Rock Auto site I come up with the following Dorman P/N's and specs for the 510 & 280ZX. Dorman #610-320 – 510 & 280ZX Rear Type Serrated Stud / Thread M12-1.25 / Knurl Dia. 12.83mm / Length 41.5mm / Shoulder Length 14mm Dorman #610-240 – 510 & 280ZX Front Type Serrated Stud / Thread M12-1.25 / Knurl Dia. 13.00mm / Length 32mm / Shoulder Length 10mm Scroll thru the Dorman Catalog on line and you’ll find several M12x1.25 studs. The link below has the studs with the closest matching knurl diameters to the Datsun. M12x1.25 Dorman Catalog This one looks promising as a longer rear stud. The knurl diameter is just slightly larger (.07mm or .003"). Dorman #610-403 – ’93-‘95 J30 (front) & ’93-’98 Quest (rear) Type Serrated Stud / Thread M12-1.25 / Knurl Dia. 12.90mm / Length 45.5mm / Shoulder Length 15mm Quote Link to comment
Ultramagnus Posted August 4, 2010 Author Report Share Posted August 4, 2010 This one looks promising as a longer rear stud. The knurl diameter is just slightly larger (.07mm or .003").Dorman #610-403 – ’93-‘95 J30 (front) & ’93-’98 Quest (rear) Type Serrated Stud / Thread M12-1.25 / Knurl Dia. 12.90mm / Length 45.5mm / Shoulder Length 15mm thanks Dave i'll look into those pt#'s. if they do pan out i'll let you all know and post pic. :D Quote Link to comment
datto510 Posted August 4, 2010 Report Share Posted August 4, 2010 I used ARP wheel studs on mine..... can't remember the part # though.I think its 110-7708. The thread pitch is 1.5 so you will need different lugnuts to go with your new studs. Quote Link to comment
Duke Posted August 4, 2010 Report Share Posted August 4, 2010 I used ARP wheel studs on mine..... can't remember the part # though.I think its 110-7708. The thread pitch is 1.5 so you will need different lugnuts to go with your new studs. Same here. They were much cheaper than going with NISMO studs, and the same length as well. Quote Link to comment
Ultramagnus Posted August 4, 2010 Author Report Share Posted August 4, 2010 (duke and datto) yeah i was reading up on the arp studs,big price diff from nismo,i wouldn't mind switching over to 1.5 but i'll see if there is a decent size on the dorman's since the LAP should have some in stock. Thanks for the reply guys and pics of the arp would be sweet! Quote Link to comment
datto510 Posted August 4, 2010 Report Share Posted August 4, 2010 (duke and datto) yeah i was reading up on the arp studs,big price diff from nismo,i wouldn't mind switching over to 1.5 but i'll see if there is a decent size on the dorman's since the LAP should have some in stock. Thanks for the reply guys and pics of the arp would be sweet! No problem man. I didn't take any pics, I didn't think swapping wheel studs was picture worthy. :rolleyes: Quote Link to comment
Ultramagnus Posted August 4, 2010 Author Report Share Posted August 4, 2010 ok i looked at the dorman #'s dimedave gave me and the one's for the j30 is about 1/4 longer than the 280zx/510 studs. i might just go w/these $22 for 12. the kurl diameter is a lil bigger but that shouldn't be an issue. it should still be good when i do the 280zx front conversion. Problem solved :thumbup: Quote Link to comment
ariascarlos1990 Posted August 5, 2010 Report Share Posted August 5, 2010 I have ARP's on my dime. They make me feel safe. =) Quote Link to comment
HRH Posted August 5, 2010 Report Share Posted August 5, 2010 When I was planning on using Maxima wheels on the 510, this came up. In my research I haven't found any longer wheel studs in the 12x1.25 pitch of Nissan/Datsun that were long enough to do any good. I did find huge long ones, even bought a set from Ichiba. www.ichibausa.com Good quality studs, variety of lengths, rather expensive. And I now have 16 of them not being used! :D Oh well, keep them around for a future project I guess. It was also suggested to drill out the studs to 1/2 and go with an American stud. Quote Link to comment
sr20ve510 Posted August 17, 2010 Report Share Posted August 17, 2010 Beating the dead horse..okay I'm retarded. :) So I have OEM Datsun in the back, what size studs do I need and what are my options? I need longer ones buy 1" I have 280z in the front, what studs do I need and what are my options? I need longer ones to match my back. 1" I would like black to match my rims. Tell me like I'm a 5 year old. Thanks for your continued patience!! lol. 1 Quote Link to comment
Ultramagnus Posted August 17, 2010 Author Report Share Posted August 17, 2010 Beating the dead horse..okay I'm retarded. :) So I have OEM Datsun in the back, what size studs do I need and what are my options? I need longer ones buy 1" I have 280z in the front, what studs do I need and what are my options? I need longer ones to match my back. 1" I would like black to match my rims. Tell me like I'm a 5 year old. Thanks for your continued patience!! lol. Depending on whether you want to change from m12x 1.25 or m12x1.50 (thread pitch of the stud) You can get the ARP studs but the thread pitch is m12x1.5 so you must change you lug nuts to fit these and the length will be more than plenty, if you have a stock wheel stud go to auto or whatever parts store that carries this Dorman PT#610-403 – ’93-‘95 J30 (front) & ’93-’98 Quest (rear) Type Serrated Stud / Thread M12-1.25 / Knurl Dia. 12.90mm / Length 45.5mm / Shoulder Length 15mm Remember the the Knurl the knuckle part of the stud will be a few cm bigger than stock 510 lug studs and may require a lil bit of elbow grease never use an impact to get a stud in. Quote Link to comment
bonvo Posted August 17, 2010 Report Share Posted August 17, 2010 i went to the parts house and got some studs from a ford there a little bigger knurel wise and they needed new lugs but they were almost an inch and a half longer and it cost me 20 bucks to do the rear Quote Link to comment
Dimerforlife13 Posted August 17, 2010 Report Share Posted August 17, 2010 I used Z32 studs, they weren't badly priced, and the local auto parts store had them. I was able to use my old lug nuts so I was happy. I did have to drill the hub just a little bit, but they worked great. Quote Link to comment
Docsis510 Posted August 18, 2010 Report Share Posted August 18, 2010 I heard that summit racing sells longer studs and that you dont have to drill the hub. i will ask and let you guys know. Quote Link to comment
Dimerforlife13 Posted August 18, 2010 Report Share Posted August 18, 2010 Drilling was very minimal with the Z32 hubs, don't remember exactly but I do remember itg wasn't much at all Quote Link to comment
Pacific coast Datsun Posted September 1, 2010 Report Share Posted September 1, 2010 Good info here. Does anybody know if this part # stud will fit into a ZX front hub ?........ Dorman PT#610-403 – ’93-‘95 J30 (front) & ’93-’98 Quest (rear) Type Serrated Stud / Thread M12-1.25 / Knurl Dia. 12.90mm / Length 45.5mm / Shoulder Length 15mm Quote Link to comment
Pacific coast Datsun Posted September 2, 2010 Report Share Posted September 2, 2010 Ok went to Kragen / O reileys today & bought 1 stud part # 610-320-1, compared to the stock 280 ZX stud it's 1/2 inch longer so it "should" work for the rims im running. I also ordered 8 of these......... Dorman #610-403 – ’93-‘95 J30 (front) & ’93-’98 Quest (rear) Type Serrated Stud / Thread M12-1.25 / Knurl Dia. 12.90mm / Length 45.5mm / Shoulder Length 15mm Ill be swapping them out Sat. & ill get comparison pix. Quote Link to comment
