DISLEXICDIME Posted July 16, 2010 Report Share Posted July 16, 2010 will 15x8 0 offset fit in the stock fenders of a 2door if i roll the fenders ? i cant remember and i failed at searching. ;) Quote Link to comment
five10freak Posted July 16, 2010 Report Share Posted July 16, 2010 they'll fit the rear after some rolling, not sure if they fit the front though Quote Link to comment
ichorid Posted July 16, 2010 Report Share Posted July 16, 2010 Lowered? 280zx struts? 200sx struts? Quote Link to comment
INDY510 Posted July 16, 2010 Report Share Posted July 16, 2010 BMW suspension??? Quote Link to comment
DISLEXICDIME Posted July 16, 2010 Author Report Share Posted July 16, 2010 O sorry. I was talking about the rears . Quote Link to comment
DISLEXICDIME Posted July 16, 2010 Author Report Share Posted July 16, 2010 And its only lowered abot 2 inchs in the rear Quote Link to comment
Jesse C. Posted July 16, 2010 Report Share Posted July 16, 2010 Roll the fenders Quote Link to comment
sssr20det510 Posted July 16, 2010 Report Share Posted July 16, 2010 if they fit on a 4 door they will fit a 2 door (15x8 0mm Sportmaxx 002) Quote Link to comment
DISLEXICDIME Posted July 16, 2010 Author Report Share Posted July 16, 2010 Any body got a 15x8 0 offset wheel I can barrow jujst to see how it looks and clears befor I spend money on wheels? I am in tgigard or Quote Link to comment
sssr20det510 Posted July 16, 2010 Report Share Posted July 16, 2010 I still think you should get the xxr 522 15x7 25mm for the fron and 15x8 0mm for the rear here is a pic where the polished the lip, its on a s14 and 17 or 18 inch but still tight Quote Link to comment
INDY510 Posted July 16, 2010 Report Share Posted July 16, 2010 Do you have a slotted rear crossmember? Or any adjustable rear camber?.................... I have seen those sportmax's on cars with crazy camber......... maybe try a 16x8 +10mm with 215/40/16 yokohama tires........... I don't think you can get that size tires for 15s The cool thing about getting a low offset Rota or Sportmaxx...... is they usually have a matching pair in 4x100 that is only 7" wide and a +25 offset (would that fit for your fronts?) Quote Link to comment
DISLEXICDIME Posted July 16, 2010 Author Report Share Posted July 16, 2010 Yes indy that is exactly what I was thinking Quote Link to comment
XeroX Posted July 16, 2010 Report Share Posted July 16, 2010 if they fit on a 4 door they will fit a 2 door (15x8 0mm Sportmaxx 002) I am pretty sure those are not 0mm offset. I have seen fitment on those same wheels on NORCALDIME's car and they poked out quite a bit more than that... The ones in the pic DEF. have some kind of possitive offset, just curious as to what... Quote Link to comment
INDY510 Posted July 16, 2010 Report Share Posted July 16, 2010 NorCalDime didn't have 280zx struts in the front......... which would have tucked the front wheels ~3/4" in on each side If you decide on 16's Dyslexic...... and you don't care about a W speed rating........ the Yokohama S drives are the lowest profile staggered set I could find: rear: 215/40/16...... front: 195/40/16 Quote Link to comment
DISLEXICDIME Posted July 17, 2010 Author Report Share Posted July 17, 2010 thanks indy but i hate running 40's every time i have ran 40 series the lips on my wheels get destroyed . maybe i will run 15x7 but it just wouldnt look as good Quote Link to comment
sssr20det510 Posted July 17, 2010 Report Share Posted July 17, 2010 thanks indy but i hate running 40's every time i have ran 40 series the lips on my wheels get destroyed . maybe i will run 15x7 but it just wouldnt look as good stay away from the curbs LOL :P Quote Link to comment
DISLEXICDIME Posted July 17, 2010 Author Report Share Posted July 17, 2010 its not curbs its pot holes Quote Link to comment
XeroX Posted July 17, 2010 Report Share Posted July 17, 2010 NorCalDime didn't have 280zx struts in the front......... which would have tucked the front wheels ~3/4" in on each side If you decide on 16's Dyslexic...... and you don't care about a W speed rating........ the Yokohama S drives are the lowest profile staggered set I could find: rear: 215/40/16...... front: 195/40/16 Didnt thing about the front suspension setup, you got me there... However the rears stuck out ALOT more than the pic of the four door above. Again leading me to believe they arent 0mm offset. I know chris (norcaldime) had to run stupid amounts of camber and pull quite a bit to get it to fit...the pic above just doesnt look right. Why would that be? If its not a different offset i mean... Quote Link to comment
DISLEXICDIME Posted July 17, 2010 Author Report Share Posted July 17, 2010 its a 15 offset Quote Link to comment
XeroX Posted July 17, 2010 Report Share Posted July 17, 2010 its a 15 offset I wonder how clearance is with rear coilovers and +15...hmmm I knew something was off! 0 offset is barrel poke central! lol Quote Link to comment
Papi Chulo Posted July 20, 2010 Report Share Posted July 20, 2010 spoprtmaxx doesnt make an 8" +15 002 wheel. That is a 0 offset wheel. I would imagine he has adjustable trailing arms, rca's w/e Quote Link to comment
paradoxx Posted July 21, 2010 Report Share Posted July 21, 2010 I have some XXR 15x8 0 off and they fit. But as long as i have the stock suspension, if someone gets on it starts to rub, although I have to say that I never finished rolling the fenders good. But sure, they fit! Quote Link to comment
dat16v Posted July 22, 2010 Report Share Posted July 22, 2010 The car in the pic has S13 front end and some surgery at the rear Quote Link to comment
novita1021 Posted August 7, 2010 Report Share Posted August 7, 2010 they fit bro youve seen the pix on my myspace when i was rocking those 002 15x8 +0 only rubbed in rear but i have too much power and no suspenssion..i have coils now and im gonna pick up another set..car look murder with them on! 1 Quote Link to comment
Fozzy510 Posted April 21, 2013 Report Share Posted April 21, 2013 Sorry to dig up an old thread. I have a 2 door 200sx struts with fender flares. 15X8 +0 would fit without any problems, correct?? Iv been searching and cant seem to find my exact setup. Everyone is either non flares or 240z struts. Thanks for the help. Quote Link to comment
