zerow Posted July 20, 2010 Author Report Share Posted July 20, 2010 I completely understand wanting to keep it returnable to stock. Would the L3 tail stock swap over? Or had you considered that.. No. The rear of the L4 is (from what I understand) where the overdrive is located. And, if you look at the pics that Datzenmike has posted, the mounting is more in the mid section of the 3N71B, where the same mounting "ears" are at the rear of the L4N71B. I have been having fits with this install, but I do want to be the first '73 610 sedan with the option installed. Mine came with auto stock, so keeping up with the original theme is what I'm going for. Quote Link to comment
MicroMachinery Posted July 20, 2010 Report Share Posted July 20, 2010 I'd like to keep my 610 in original shape, as well as reduce the temptation to drive in a manner that could wind me up in a ditch. I'm keeping the Auto as well, but I'd like more out of it. Just a coincidence that you two happened to be doing this at the very same time. Lucky me :) As far as the OD is concerned, isn't it in that front section of the transmission? The one that goes between the bellhousing and main body? I wouldn't think the tail stock would house the OD.. I could be wrong, though. I'm sure that you've researched this quite a bit more than I have.. Quote Link to comment
zerow Posted July 20, 2010 Author Report Share Posted July 20, 2010 It is in the front portion of the transmission. Correct. But the tailshaft is L4N71B specific. Observe: (Thanks to Datzenmike) The 3N71B is in the bottom of this pic. Quote Link to comment
MicroMachinery Posted July 20, 2010 Report Share Posted July 20, 2010 True, but that L3 is from a pickup. The 510's have a shorter tailstock... looks very similar to the L4. I'll go take a picture of one. Quote Link to comment
zerow Posted July 20, 2010 Author Report Share Posted July 20, 2010 True, but that L3 is from a pickup. The 510's have a shorter tailstock... looks very similar to the L4. I'll go take a picture of one. That L3 is the same as mine from the 610. You know of a shorter L3? Looking forward to the pics! Quote Link to comment
MicroMachinery Posted July 20, 2010 Report Share Posted July 20, 2010 Yes. The L3 that comes out of the 510 has a stubby tail shaft. I went out and took some pics, and I'm waiting for them to reach photobucket :rolleyes: , but it looks like while they are similar, they are not the same. The 510 L3 has 4 bolts that hold it to the main body, whereas the L4 looks to have atleast 6 bolts. I think, however, that the 510 L3 mount/crossmember may work with the L4 tail stock. I'll put up pics as soon as they arrive to my photobucket account. Quote Link to comment
zerow Posted July 20, 2010 Author Report Share Posted July 20, 2010 Yes. The L3 that comes out of the 510 has a stubby tail shaft. I went out and took some pics, and I'm waiting for them to reach photobucket :rolleyes: , but it looks like while they are similar, they are not the same. The 510 L3 has 4 bolts that hold it to the main body, whereas the L4 looks to have atleast 6 bolts. I think, however, that the 510 L3 mount/crossmember may work with the L4 tail stock. I'll put up pics as soon as they arrive to my photobucket account. Please do! Which 510? The PL510 or the HL510? Quote Link to comment
datzenmike Posted July 21, 2010 Report Share Posted July 21, 2010 I was wondering if the shorter output spline from a PL 510 would swap into the L4N71B to get rid of the 26 spline one. I pondered that on the realm. I have a picture of a shorty 3N71B but it's for a 210 or something. Put an L bell on it and it would fit the 510.: Bet it's the same length. Bet also that the output spline would swap. BTW here is a pix of the PL510 auto but it doesn't show much. . Quote Link to comment
zerow Posted July 21, 2010 Author Report Share Posted July 21, 2010 I want to know more about the mount on the first pic. 210, you say? It appears that the 210 mount is the style similar to the 610 mount. Saddle style. If the bolts are the same distance apart like the 3N71B, then it is a viable alternative, only if you obtain the tail section of the L3N71B. I don't mind cannibalizing transmissions, but I'm looking at cost for cost items. I can't go to every yard in the hopes of finding this unicorn when I have the L4N71B right here. I need my adaptor... Quote Link to comment
MicroMachinery Posted July 21, 2010 Report Share Posted July 21, 2010 My pics still haven't made it to photobucket. WTF! I'm sending them again. :angry: Quote Link to comment
MicroMachinery Posted July 21, 2010 Report Share Posted July 21, 2010 Ok, so my pics FINALLY came up on photobucket... :rolleyes: Here's the tail stock for the L4, which we're all familiar with: Here's the PL510 tail stock(L3): These are not interchangeable, apparently. The L3 uses 4 bolts to hold it to the main body, and the L4 uses more.. 8+ I think? I'm still not sure if the PL510 L3 Mount can or cannot be utilized for our purposes.. Quote Link to comment
zerow Posted July 22, 2010 Author Report Share Posted July 22, 2010 No interchange on the tailstock for sure. It appears that the mount on the 3N71B is wider (from bolt to bolt) than the L4N71B. This is where my adaptor is going to take up the slack. Pics as soon as it is ready. Gotta get this joker. And soon... :rolleyes: Quote Link to comment
datzenmike Posted July 22, 2010 Report Share Posted July 22, 2010 I was wondering if the output spline would swap so I can get rid of the 26 tooth and run a regular Datsun drive shaft???? Quote Link to comment
MicroMachinery Posted July 22, 2010 Report Share Posted July 22, 2010 I haven't gotten to that point yet. I'll let you know when I do. Quote Link to comment
MicroMachinery Posted October 6, 2010 Report Share Posted October 6, 2010 Sooo.... ... what ever happened with this? Quote Link to comment
zerow Posted February 3, 2011 Author Report Share Posted February 3, 2011 Sooo.... ... what ever happened with this? Zerow has been patiently sourcing parts... So, now I need to ask others if this list seems correct (I have slept since I pulled this transmission from the yard...these are the parts I have): Rear Main Engine Seal Engine to transmission Mating Plate (anyone ever seen a two-piece variety...?? I have one apparently) End of Crankshaft Adapter for Automatic Flexplate (remove pilot bushing prior to install!) L4N71B Flexplate with bolts Front main transmission seal Torque Converter for L4N71B with bolts to flexplate Vacuum Hard Lines Transmission coolant lines to front of car Associated hardware to bolt engine to transmission Am I missing anything...??? :confused: Quote Link to comment
datzenmike Posted February 3, 2011 Report Share Posted February 3, 2011 You do not have to remove the pilot bushing. Tranny interlock and reverse lights. The floor shift rod will need to be shortened as the main case sits back about 6? inches. Quote Link to comment
zerow Posted February 3, 2011 Author Report Share Posted February 3, 2011 You do not have to remove the pilot bushing. Tranny interlock and reverse lights. The floor shift rod will need to be shortened as the main case sits back about 6? inches. I am making a harness to mate the stock wiring to the L4N71B OD switch (just needs relayed 12 volts for cancel of the OD...), interlock and reverse light switch. The floor shift rod has to be shortened? I have both the 3N71B and the L4N71B rods - I was just going to use the L4N71B rod... Quote Link to comment
MicroMachinery Posted February 3, 2011 Report Share Posted February 3, 2011 What what WHAT? An update? :D Quote Link to comment
datzenmike Posted February 3, 2011 Report Share Posted February 3, 2011 - I was just going to use the L4N71B rod... ..... of course. Quote Link to comment
ariascarlos1990 Posted February 3, 2011 Report Share Posted February 3, 2011 I have a 3 speed auto you can have for parts or whatever. Quote Link to comment
zerow Posted February 3, 2011 Author Report Share Posted February 3, 2011 What what WHAT? An update? :D Yes, Micro, finally an update...School has been keeping this man down. I felt real damn good after the instructor (its an algebra class...) puts this huge ass formula on the board. And with a smug look on his face tells us that the first part of the equation is for the weekly quizzes and the second is for homework. This is your grade at the moment...Plug in your test and homework scores...I have a 95.86 out of 100 in the class...Woot! I have a 3 speed auto you can have for parts or whatever. Thanks Arias! I have a three speed with some hardware left on it still. If I need anything, I will hit you up! Quote Link to comment
zerow Posted June 30, 2011 Author Report Share Posted June 30, 2011 Okay...yes, I know, I know...an update... The transmission and driveline are IN. It was the only way she would be running right now. Now, I have some other hurdles to overcome...like the fact that it is propped up on the rear mount with 36 (or so) fender washers and two bolts... Now, What I need is a wiring diagram from an 83 Maxima service manual...namely the color codes for the wires at the transmission. It seems to me that the kickdown solenoid wires through the OD cancel solenoid for whatever reason...please correct me if I am wrong... (What was the word I have to put into a post to get datzenmike's attention...?) I will post ALL of the pictures from the installation after my visit to the machine shop for the new spacers. Spoiler Alert: The driveshaft fit perfectly! Quote Link to comment
Guest 510kamikazifreak Posted June 30, 2011 Report Share Posted June 30, 2011 (What was the word I have to put into a post to get datzenmike's attention...?) DOUCHE is the word ollz Quote Link to comment
Laecaon Posted June 30, 2011 Report Share Posted June 30, 2011 DOUCHE is the word ollz I thought it was DOUCHEBAG... Quote Link to comment
