djmoreron Posted December 17, 2007 Report Share Posted December 17, 2007 newbie question again... truck just started making a rattling noise recently. kinda sounds like a loose bike chain. its intermittent... happens when the truck idles or when i let off the gas while driving. sounds like its coming from underneath near the front of the engine. my guess would be timing chain?? :confused: truck drives completly normal. no loss of power or anything. any ideas? Quote Link to comment
RacnJsn95 Posted December 17, 2007 Report Share Posted December 17, 2007 Sounds like you might need to adjust your rockers? Quote Link to comment
datzenmike Posted December 17, 2007 Report Share Posted December 17, 2007 The chain tensioner uses oil pressure from behind, (plus a spring) to push against the chain and keep it tight. At idle, the oil pressure will be much lower so maybe that's it. The chain guide may also be worn. Beware, a very loose chain could rub a hole in the chain cover, not to mention the aluminum filings going through the oil pump on their way to the filter. Quote Link to comment
Voleurz Posted December 17, 2007 Report Share Posted December 17, 2007 when i had a nissan pulsar it made a terible noise ( the timing chain) turns out the oil was too thin. Quote Link to comment
djmoreron Posted December 17, 2007 Author Report Share Posted December 17, 2007 thanks for the info. wasnt sure where to begin with this. ill check what i can... and if all else fails ill call a friend of mine over to come help me out. :D Quote Link to comment
pl521sss Posted December 17, 2007 Report Share Posted December 17, 2007 when i had a nissan pulsar it made a terible noise ( the timing chain) turns out the oil was too thin. Or not enough Oil I just had that noise a couple of days ago. Checked OIL, none on the dip stick. Yikes Filled it up, no more noise on idle. Quote Link to comment
datsunfish Posted December 17, 2007 Report Share Posted December 17, 2007 That sounds like what happened to my 620 recently.It would intermittently rattle when lettlng off the gas.Turned out to be a broken timing chain guide.Figured that out after I pulled it and threw in a different l18.Change your oil and inspect for small plastic particles.Take off the valve cover and inspect the guides from there. Quote Link to comment
ggzilla Posted December 18, 2007 Report Share Posted December 18, 2007 The newer engines are notorious for timing chain going bad before 100,000 miles. The L-series is longer lasting. But anyways it is easy to check, just pull the rocker cover and see how much slack is in it. Or try the turn engine-back and see how far it moves before distributor rotor moves. Quote Link to comment
datzenmike Posted December 18, 2007 Report Share Posted December 18, 2007 If you think about it, chain slop won't affect the dizzy, it's driven by a worm gear on the crank. Gotta love the double row L and Z timing chains. Pity the KA24s with the single chain. Even this angle you can see how flat the single chain KA sprocket is. Looks like the L and Z would interchange. How do you adjust for chain stretch on a KA anyway??? http://i138.photobucket.com/albums/q251/datzenmike/CopyofIMG_0433.jpg[/img]"] Quote Link to comment
71-521 Posted December 18, 2007 Report Share Posted December 18, 2007 while you're checking stuff, look at your water pump...try and wiggle the fan blade...if it moves you might want to change it before it eats your front cover. Quote Link to comment
