NWOleman Posted December 16, 2007 Report Share Posted December 16, 2007 Ok i want disc on all four, but want to do it cheap and easy. I have a 73' 610 wagon with a solid rear axle. Did any of the cars come with a solid rear axle with disc or what about the trucks? Thanks NWOleman Quote Link to comment
datzenmike Posted December 16, 2007 Report Share Posted December 16, 2007 The '80-'83 200sx had rear disc brakes on a solid rear axle but it is a coil spring set up if you are thinking of an axle swap. The disc has the right bolt pattern and the caliper has a built in E-brake too. There is a four bolt backing plate that mounts to the axle tube and holds the caliper. When I took the axles out, the backing plate won't slide off the axle because the wheel bearing is in the way. The bearing would have to be remover first. Jason Wong has them now I think. He's the guy to see about pictures of it. He has plans to do the same thing, see him. The first Nissan trucks with rear disc brakes were the '87 WD-21 Pathfinder with 7.84" rears, it is a coil spring rear too, but has the monster H233 ring gear. The D21 had 10" drums Pathfinder WD-21 rear discs and H233 rear end. (note coil spring) http://i138.photobucket.com/albums/q251/datzenmike/DSC01183.jpg[/img]"] The pathfinder with Sport Package option and VG30 TBI had an optional 4.475 LSD, the automatic was a 4.625 LSD. The D21 Hard Body w/VG30 TBI automatic had 4.375 LSD (but no rear discs) Quote Link to comment
kiznook Posted December 16, 2007 Report Share Posted December 16, 2007 Mike- I've always been under the impression that the H233 was a 9.18" ring gear, have I been wrong all this time? I would look into a mid 80s corolla or early supra rear end, LOTS of parts available (gearsets and LSDs) and factory disc brakes, but again, its a link and coil setup so you'll have to chop all of that off and add leaf spring perches, or convert your car to 4-link :cool: you could even save the swaybar from the yota too :D Quote Link to comment
datzenmike Posted December 16, 2007 Report Share Posted December 16, 2007 Good catch Kiz. Should have drank more or less coffee this morn. Yeah it's 233, good for hundreds and hundreds of foot pounds. Quote Link to comment
Bleach Posted December 17, 2007 Report Share Posted December 17, 2007 There will probably be no bolt-on rear disc swaps but if you're looking for a conversion then you probably will only need to make a caliper mounting bracket. 280ZX rear calipers are easy to find and they are 4-lug Quote Link to comment
