HOT-SX Posted May 21, 2015 Report Share Posted May 21, 2015 Thanks datsunfreak. Sorry to hear about your S12. That has to hurt. I use my Pathfinder as my daily driver so that I never have to drive the S12 in the rain. Even first gen Pathfinders are becoming a pretty rare sight, at least on the east coast. I think Cash for Clunkers took out 2/3's of them and rust got almost every one that was left. Mine had one rusty spot in the rocker. I just repaired it last week. It looked a little scaly so I thought I was going to scrub it with a wire brush and paint it with POR15 but after brushing it I poked around with a screw driver. I easily poked a hole through he rocker. By the time I cut a patch out and started welding and blowing out more and more metal I ended up with an 1 1/2 hole to repair. It's all welded up now (and painted with POR15). Hopefully that prevents it from rotting further. The S12 doesn't have a speck of rust anywhere. It was coated with Ziebart's by the dealership and maintained by Ziebart. That stuff works great. The Pathfinder should have had the same treatment! Quote Link to comment
HOT-SX Posted May 21, 2015 Report Share Posted May 21, 2015 And I'll never give you any guff for keeping the miles off it. Wish I had done the same with mine. :rofl: Check this out. The mileage chart for my 85 S12. It had 65,000 of it's miles put on in less than 4 years and another 12,000 in all the time since. New 09/10/1985 7,503 02/06/1986 12,954 04/24/1986 16,266 05/29/1986 17,709 06/11/1986 22,875 08/21/1986 30,145 12/03/1986 65,192 03/02/1989 68.647 08/25/1989 Pretty much retired in 1989 with 68,647 miles 70,236 07/15/1991 72,196 07/30/1994 74,083 08/28/1998 74,275 07/22/2000 74,456 08/11/2001 75,960 08/29/2011 that's 1500 Miles in 10 years! 76,037 06/11/2014 and just 2000 miles in 16 years! Quote Link to comment
relaxed atmosphere Posted June 19, 2015 Report Share Posted June 19, 2015 a little update on my 200sx Quote Link to comment
DREWSDIME Posted June 25, 2015 Report Share Posted June 25, 2015 What size and offset are your rims? Quote Link to comment
datzenmike Posted June 25, 2015 Report Share Posted June 25, 2015 The S110 (second gen) also began the use of the new Z series NAPS engines and the stronger 71B 5 speeds.. Quote Link to comment
HOT-SX Posted June 30, 2015 Report Share Posted June 30, 2015 I like it! I like it a lot, scooter. Do you have any interior shots? Quote Link to comment
scooter Posted June 30, 2015 Report Share Posted June 30, 2015 Somewhere, i have to find them... 1 Quote Link to comment
ArchetypeDatsun Posted July 8, 2015 Report Share Posted July 8, 2015 Update... What type of coilovers? I'm fairly new to the 200sx I still haven't picked it up trying to finish up a truck I'm using to do the trade. I'll be looking into doing the front with coilovers pretty much the setup you got. Quote Link to comment
scooter Posted July 8, 2015 Report Share Posted July 8, 2015 I bought these off a member here, theyre s12 200sx struts cut down for mr2 inserts, ground control sleeves and camber plates.. The rca is s10 200sx/510 on the knuckle end and bigger on the top as the reciever hole on s12 struts is bigger, but the bolt pattern is still the same. If i was going to do anything different it would be to find some longer springs as these ones are wound up to damn near the top. Theyre eibach 275# springs, they have settled about an inch so far. They are vented discs, the calipers arent huge but are a huge improvement over s10 calipers. Im trying to get a z32 caliper to see if it bolts on and fits in the 13 inch rims.. Bwahaha.. Right now theres lots of clearance left with these 13's dunno with an aluminum rim though. Now for a bre style sway bar... Quote Link to comment
ArchetypeDatsun Posted July 9, 2015 Report Share Posted July 9, 2015 Right on man love seeing these get the attention they deserve. Mine is gonna have fender flares already so I mirth stick to the 13's for awhile but might move up to 14's if I can't find some cool wide 13's. Quote Link to comment
scooter Posted July 12, 2015 Report Share Posted July 12, 2015 I have to pick up my flares when i get home, i have one inch spacers for the front to fill out the flares, and i procured a mustang 8.8 for the rear thatll be redrilled for datsun bolt pattern and a detroit locker, and a good width to fill the rear flares, i may drop the rear an inch or two so it has less rake. Im looking at getting some composite rear leafs built too. This thing is pretty much turning into a pro tourer kinda build. Archetype, the rims i have are bassett inertia advantage series, theyre probibly the lightest steel rim your going to find, they come in a 13x7 or 8 in many offsets. I think these have an inch of negative offset? I cant remember. Those are 205/60r13's, toyo ra1's. So far i havint been able to get this thing to slide, ive thrown this thing into corners wayyy faster then i would before, and it just sticks like glue. I wanna find one of those big sumimoto calipers and see if these rims clear, as of right now i think they might with a little massaging, i can get my fingers between my current calipers and rim. Quote Link to comment
derrick719 Posted July 20, 2015 Report Share Posted July 20, 2015 Update... Hey scooter saw you cruising by skaha lake on Saturday morning. Car looks awesome. My brother lives there and always saw you around. He wants to know What engine are you running in your car Quote Link to comment
scooter Posted July 21, 2015 Report Share Posted July 21, 2015 Lol i live 2 blocks from skaha lake. Its an lz 2.3 done right up. It makes quite the noise and people ask me all the time what the hells in that thing haha. The flares have showed up and hopefully should be going on later this week. Quote Link to comment
derrick719 Posted July 21, 2015 Report Share Posted July 21, 2015 Ya my brother thought it was a v8 Quote Link to comment
derrick719 Posted July 21, 2015 Report Share Posted July 21, 2015 What's a lz from? Quote Link to comment
Burabuda Posted July 21, 2015 Author Report Share Posted July 21, 2015 @scooter Quote Link to comment
datsunfreak Posted July 22, 2015 Report Share Posted July 22, 2015 What's a lz from? Nothing. :rofl: It's a name often (erroneously) used to describe an L/Z hybrid engine. In other words, using an L-series head, and the bottom half of a Z20/Z22/Z24 engine. Or conversely you can bore an L20B and install the Z22 crank/rods/pistons to build an L22. There are many combinations of parts you can use to build an L-series engine well over 2000cc. Personally, I think it's silly to call it that because that name is taken. B) This is an LZ engine. Quote Link to comment
scooter Posted July 22, 2015 Report Share Posted July 22, 2015 Ok its a frankenstein. Z22 block, z22 crank, l20b rods shot peened and arp bolted, custom cp flat top pistons, all balanced. Head is a u67 casting, ported with 45 mil ferrea undercut stem supercomp intake valves, 36mm ferrea undercut exhaust valves, isky springs and retainers, isky z-196 grind cam. Ported cannon intake with nitrous fogger setup. Weber 45's with 40 mil throats Lightened 225 mil flywheel, act clutch Msd digital 6 plus ignition with new ei dizzy. Racetep l series header, 2.25 straight exhaust to dynomax pro flo muffler. Quote Link to comment
fritzdixxon Posted July 22, 2015 Report Share Posted July 22, 2015 Nicely done, I am toying with the idea of doing some kind of ka/l/z hybrid of some sort haven't decided which way to go yet, that will happen after I get the l20b back in my wagon. Where in B.c. are you scooter? Quote Link to comment
scooter Posted July 22, 2015 Report Share Posted July 22, 2015 Ive had a few people ask me if theres a v8 in it lol Quote Link to comment
scooter Posted July 22, 2015 Report Share Posted July 22, 2015 Nicely done, I am toying with the idea of doing some kind of ka/l/z hybrid of some sort haven't decided which way to go yet, that will happen after I get the l20b back in my wagon. Where in B.c. are you scooter? If i was gonna do it again, id probibly just ka it, or sr20 it. But the l motor all hopped up is pretty awesome. Quote Link to comment
fritzdixxon Posted July 22, 2015 Report Share Posted July 22, 2015 The one I am building will only cost me aset of plugs and a gasket kit so I am going to try it just for shits an giggles, there will be some form of forced air as well. Even if it only lasts for one race day I will be happy. Quote Link to comment
scooter Posted July 22, 2015 Report Share Posted July 22, 2015 My experiences with l motors so far has showed that their pretty much bomb proof. I really like these engines. Quote Link to comment
fritzdixxon Posted July 22, 2015 Report Share Posted July 22, 2015 So far I've been super happy with the stock '78 smog car, I Canadian winter drive the wagon so traxtion is something you have a lot of throttle control over. I really just want to play with the interchangeability of various heads, for no other reason than because they can interchange. Quote Link to comment
