hosestop@msn.com Posted December 17, 2015 Report Share Posted December 17, 2015 How far Ray ? also how is the transmission ,It can just the trans work. Quote Link to comment
TENDRIL Posted December 17, 2015 Report Share Posted December 17, 2015 500+ miles over a pass or two Quote Link to comment
paradime Posted December 17, 2015 Report Share Posted December 17, 2015 I'd like to build a 521, or 620 with a fifth wheel tow hitch so I can flat bed trailer my 2000lb. 510 for track days. The car has plates, but if it breaks down at Sonoma, or Laguna Seca, I want to be able to get it home. I would imagine the load would be near 3300lb. Obviously 55mph is as fast as I'd go, but my greatest fear is a terminal sway harmonic. I've read that putting the tow point directly over the rear axle, and having the trailer as low as possible really helps with stability. Another contributing factor to sway harmonic is the amplification of the load swaying. Fortunately, this is not an issue with my car. In the pursuit of safety, what other upgrades to the truck would you guys recommend? Discs up front, electric trailer brakes, heavier leaf springs and axles, Dualies? Quote Link to comment
hobospyder Posted December 17, 2015 Report Share Posted December 17, 2015 I beleive wayno would be the best person to talk to in this pursuit, I'm pretty sure he is the one that overbuilt for hauling 1 Quote Link to comment
datzenmike Posted December 17, 2015 Report Share Posted December 17, 2015 500+ miles over a pass or two Check the towing limits on the Toy. May be in the glove box booklet. Air up the tires. If towing with rear wheels on ground take the driveshaft off and tie securely out of the way. Mark the U joint so it goes back on the same way it came off. Expect this to weigh barely under 2,300 pounds. Trailer? add to the car weight. Automatics are fried almost exclusively from over heating and you'll never know it as it happens. The trans coolers are little more than 8" or metal tubing inside the bottom rad tank surrounded with hot water. How these thing ever last 100K is beyond me. I would get the largest RV trans cooler you can find and splice into the trans cooler return line. Check the ATF and DO NOT over fill it if climbing hills. Check fan belts and fluid levels specially the rad. This is going to cause the Toy to work 5 times as hard as on the level and will tax everything to the limit. Take water with you. Down hill if you smell the brakes pull over irregularly and let them cool. Use lower gear for engine braking. Don't use over drive on the flat. Quote Link to comment
TENDRIL Posted December 17, 2015 Report Share Posted December 17, 2015 ok im going to go look for a trans cooler at my local junk yard no is it important how high or low to mount the newer larger cooler ? in relation to the trans dip stick? and when adding more trans fluid do i do it running? hot or cold? this is my first auto, i did check it when i bought it and cold it was at the proper level, honestly i have not checked it hot Quote Link to comment
bilzbobaggins Posted December 17, 2015 Report Share Posted December 17, 2015 When was the last time the trans and brakes were services? We regularly went beyond towing capacity with our box truck. Kept the transmission serviced and it's no worse than when new. Lots of trips all over the south in and out of the mountains Quote Link to comment
TENDRIL Posted December 17, 2015 Report Share Posted December 17, 2015 front brakes are new, not sure about rear, guy i bought it from said he had the trans filter and fluid changed within the last year fluid is not as red as id like but is not brown or tan Quote Link to comment
Draker Posted December 17, 2015 Report Share Posted December 17, 2015 Check the tranny warmed up and in neutral. Shift through all gears, then place in neutral. Any external oil cooler will work. Just make sure it's getting air flow. Does your toyota have a temp warning light? Mine does. Quote Link to comment
Lockleaf Posted December 17, 2015 Report Share Posted December 17, 2015 I wouldn't even bother with a Junkyard. Trans coolers are cheap. O'Reilly Auto should have they're largest one for like $65 or so. Brand is Hayden. 1 Quote Link to comment
kneesamo Posted December 17, 2015 Report Share Posted December 17, 2015 @Z23T, yes BRC-DPW. Quote Link to comment
datzenmike Posted December 17, 2015 Report Share Posted December 17, 2015 Change the fluid if you can afford it. Think about McDees fryer oil. Works best when new. ATF will degrade from excess heat and loosee it's friction modified properties. The dark coloring is friction material coming off the clutch discs. It's not filtered by the filter and is abrasive to everything in the automatic. . Quote Link to comment
TENDRIL Posted December 20, 2015 Report Share Posted December 20, 2015 so i think i over filled my trans, whats more important the fluid level cold or hot ? It is a bit sluggish and when i checked my fluid hot it was over filled, but when i added the fluid cold it was within the marks for cold Quote Link to comment
datzenmike Posted December 20, 2015 Report Share Posted December 20, 2015 Warm in neutral engine running. Not to be above the line. The add line is only 1/4 liter below the Full line Quote Link to comment
TENDRIL Posted December 20, 2015 Report Share Posted December 20, 2015 Ok I'm going to drain a half a quart roughly and re try . So I remember reading some where "cool" is 85-100 or something like that and hot is 130- 180 or something like that, so when you say warm, should I drain,drive, park, rest start back up and idle in neutral check? Quote Link to comment
datzenmike Posted December 20, 2015 Report Share Posted December 20, 2015 Run for at least 10 min. Take for a drive. Then check idling in neutral. Quote Link to comment
