flatcat19 Posted February 3, 2016 Report Share Posted February 3, 2016 As close as I'll ever get.lol Valient effort. 1 Quote Link to comment
Dguy210 Posted February 8, 2016 Report Share Posted February 8, 2016 I want one of these so bad, I'm not even sure if there is one in all of the US. Problem is for the cost of importing one of these you might as well get a skyline or 510 coupe. Quote Link to comment
datsunfreak Posted February 9, 2016 Report Share Posted February 9, 2016 Problem is for the cost of importing one of these you might as well get a skyline or 510 coupe. Except when you buy it in Japan, it'll cost 1/3 the price of a Bluebird Coupe and 1/4 the price of a Skyline. ^_^ Yeah, they all cost the same to import, but when the buy-in is so much cheaper... And you'll likely have the only one, ever... 1 Quote Link to comment
JDOM310 Posted February 11, 2016 Report Share Posted February 11, 2016 Hey fellas , not sure if anyone on here can help i have been trying to start my 210 for a while now maybe 4 weeks when i can , I have rebuild carb (hitachi) installed new fuel pump dizzy and wires and spark-plugs and nothing, then one of the guys on here suggested fuel tank lines might be plugged so i took out gas tank and blew all the lines with air hose and emptied tank with fuel that had been sitting there for months, the car will turn over just nothing starts. I am considering buying a new carburetor. I checked the filter and no fuel will come through unless i siphon and even then it will not continue to flow. i am pretty sure the fuel pump is installed correctly, could this be a vaccumm hose or a line that is still clogged?> any suggestions, sorry if im all over the map its just i am trying to avoid taking it to a shop, i feel like there is still something i can look into at home and get it running./ Quote Link to comment
JDOM310 Posted February 11, 2016 Report Share Posted February 11, 2016 Oh Ab Froman , that is what i want my 210 to look like when it grown up... darn CA smog regulations Quote Link to comment
flatcat19 Posted February 11, 2016 Report Share Posted February 11, 2016 Do you have fuel leaving the fuel pump? What happened prior that made you replace all those parts? Quote Link to comment
JDOM310 Posted February 11, 2016 Report Share Posted February 11, 2016 What happened was it had been in storage for like 8 months and i noticed that when i wanted to start it there was no fuel in the fuel filter at all so, then i proceeded to ask on here and fuel pump was suggested so i replaced it, also before that someone here suggested to rebuild the carb and i did, when that didnt work they suggested fuel lines. now it seems like i might have to back track. any advice welcomed. Quote Link to comment
JDOM310 Posted February 11, 2016 Report Share Posted February 11, 2016 after storage spark plugs were replaced, new battery , new fuel pump, new fuel filter, new dizzy, and rebuild carb. Quote Link to comment
Germ_555 Posted February 12, 2016 Report Share Posted February 12, 2016 New fuel pump might be bad. I would try a electric fuel pump before installing new carb, also make sure hose isn't pinched. Quote Link to comment
flatcat19 Posted February 12, 2016 Report Share Posted February 12, 2016 Do you have fuel leaving the fuel pump? Stop replacing parts. Let's diagnose this thing. Quote Link to comment
JDOM310 Posted February 12, 2016 Report Share Posted February 12, 2016 Believe me man I do not wanna buy more parts it's just was running ok before parked Then a while later would not start I just want my datsun running so I cane joy it as a daily Quote Link to comment
JDOM310 Posted February 12, 2016 Report Share Posted February 12, 2016 Ok let's diagnose I am game I get a good solid day a week to work on it so might take a while . Suggestion Quote Link to comment
flatcat19 Posted February 12, 2016 Report Share Posted February 12, 2016 Again...do you have fuel exiting the fuel pump? Quote Link to comment
Germ_555 Posted February 12, 2016 Report Share Posted February 12, 2016 Is there gas in the tank -Are the lines connected & clear - Is gas being pulled to fuel pump? Quote Link to comment
JDOM310 Posted February 12, 2016 Report Share Posted February 12, 2016 Lines all connected no gas being pulled and yes gas in tank Quote Link to comment
JDOM310 Posted February 12, 2016 Report Share Posted February 12, 2016 All lines clear and fastened Quote Link to comment
JDOM310 Posted February 12, 2016 Report Share Posted February 12, 2016 Gas does not make it to fuel pump Quote Link to comment
flatcat19 Posted February 12, 2016 Report Share Posted February 12, 2016 Pick up or pump. Quote Link to comment
JDOM310 Posted February 12, 2016 Report Share Posted February 12, 2016 Mechanical fuel on a 1980 210 a14 Quote Link to comment
JDOM310 Posted February 12, 2016 Report Share Posted February 12, 2016 Checked all lines leaving and entering tank Quote Link to comment
pojobo Posted February 19, 2016 Report Share Posted February 19, 2016 My 79 210. Stock except for weber. Used to have partial vinyl roof, haven't ever seen that before. 1 Quote Link to comment
datzenmike Posted February 19, 2016 Report Share Posted February 19, 2016 Very nice!!! Like the factory mags. 1 Quote Link to comment
