Docsis510 Posted May 26, 2010 Report Share Posted May 26, 2010 I was doing a rear disc brake conversion on my 510 and my dumb ass jacked up the threads on the driver side stub axle. let me know if you guys have one thanksss. Link to comment
Chris#51EPGraham Posted May 26, 2010 Report Share Posted May 26, 2010 I was doing a rear disc brake conversion on my 510 and my dumb ass jacked up the threads on the driver side stub axle. let me know if you guys have one thanksss. I've got one. Have never pulled a stub axle before...can you advise as to how hard they are to slide hammer out and any other problems/mistakes to avoid? Link to comment
thisismatt Posted May 26, 2010 Report Share Posted May 26, 2010 I've got one. Have never pulled a stub axle before...can you advise as to how hard they are to slide hammer out and any other problems/mistakes to avoid? The stub axle nut has a thin lip/ridge that is peened over onto flats on the stub axle to lock it in place. You have to cut away these peened over spots in order to get the nut off. Docsis510 - if you only damaged the thread at/above the peened over nut section it's probably still fine to use. Link to comment
Docsis510 Posted May 26, 2010 Author Report Share Posted May 26, 2010 yeah that nut is what did it. i used the air gun on it without knowing that i had to cut those bent pieces out. Link to comment
Chris#51EPGraham Posted May 26, 2010 Report Share Posted May 26, 2010 I knew about the peened nut flange. I now have a left axle out and cleaned up if you decide you need it. The big nut threading looks to be M20 x 1.25. Not sure how easy it is to find that size, but a machine shop can easily modify a standard nut to create the peening flange like that. I don't know of anywhere to get new or NOS nuts. Link to comment
thisismatt Posted May 26, 2010 Report Share Posted May 26, 2010 I knew about the peened nut flange. I now have a left axle out and cleaned up if you decide you need it. The big nut threading looks to be M20 x 1.25. Not sure how easy it is to find that size, but a machine shop can easily modify a standard nut to create the peening flange like that. I don't know of anywhere to get new or NOS nuts. Nissan, 43262-21000 (or 43262-21050). Link to comment
Chris#51EPGraham Posted May 26, 2010 Report Share Posted May 26, 2010 Nissan, 43262-21000 (or 43262-21050). Nissan dealers still have them, d'you think? (probably lots of them because everyone assumes they're NLA like I do :lol: ) That bearing number you posted in the steering box thread - that was a Nissan part #, not a generic bearing number? Speaking of which, the 510 sedan rear wheel bearings are generic bearing # 6206 with the suffix OA or DA, 30mm x 62mm x 16mm. Do you know if Nissan sells or sold 510 sedan rear wheel bearings strictly in matched (duplex toleranced) pairs? Duplexes are for shafting designs where inner and outer races must both be mounted rigidly within ten thousands of the same length. Link to comment
hang_510 Posted May 26, 2010 Report Share Posted May 26, 2010 Nissan dealers still have them, Do you know if Nissan sells or sold 510 sedan rear wheel bearings strictly in matched (duplex toleranced) pairs? yes they do! :) got mine last year and were avail at the local dealer (for more $$ of course <_< ) IIRC they do not. i had a Q about matching and never got an affirmitave yes from anyone. just used what i received. Link to comment
Chris#51EPGraham Posted May 26, 2010 Report Share Posted May 26, 2010 yes they do! :) got mine last year and were avail at the local dealer (for more $$ of course <_< ) How much $? IIRC they do not. i had a Q about matching and never got an affirmitave yes from anyone. just used what i received. At a dealer, right? That leads me to believe the assembly is not designed around duplex pairs. They'd be worried about liability otherwise. I can attest that those humble 6206 bearings will last at least 300k miles based on the '69 510 I owned. I bought that car thrashed with a chrome re-ringed engine that was nearly worn out, then wore out another low mileage engine/trans in it over another 100k miles. I'm figuring 200k on engine #1 + 100k (in that car) on engine #2. Same rear wheel bearings all along. Link to comment
hang_510 Posted May 26, 2010 Report Share Posted May 26, 2010 I can attest that those humble 6206 bearings will last... ive not heard any REAR wheel bearing failures. the set i replaced were heavily abused, & if it wasnt for all the effort pulling apart and never wanting to do it again, i would have put em back in. Link to comment
thisismatt Posted May 27, 2010 Report Share Posted May 27, 2010 Nissan dealers still have them, d'you think? (probably lots of them because everyone assumes they're NLA like I do :lol: ) That bearing number you posted in the steering box thread - that was a Nissan part #, not a generic bearing number? Speaking of which, the 510 sedan rear wheel bearings are generic bearing # 6206 with the suffix OA or DA, 30mm x 62mm x 16mm. Do you know if Nissan sells or sold 510 sedan rear wheel bearings strictly in matched (duplex toleranced) pairs? Duplexes are for shafting designs where inner and outer races must both be mounted rigidly within ten thousands of the same length. I didn't post anything in the steering box thread, so I don't know. I don't think Nissan ever sold the bearings in a set, and I don't think the tolerances really need to be that precise for wheel bearings (I mean if you consider how front wheel bearings are setup on all these style nissan struts there's actually a fair amount of play). Yes, 6206 is the generic number and I don't know of anyone who buys them from nissan when you can get them a lot cheaper elsewhere. I think 6206-2RS is the style I have, which are double sealed unlike the stock ones. Link to comment
Chris#51EPGraham Posted May 27, 2010 Report Share Posted May 27, 2010 I didn't post anything in the steering box thread, so I don't know. I don't think Nissan ever sold the bearings in a set, and I don't think the tolerances really need to be that precise for wheel bearings (I mean if you consider how front wheel bearings are setup on all these style nissan struts there's actually a fair amount of play). Yes, 6206 is the generic number and I don't know of anyone who buys them from nissan when you can get them a lot cheaper elsewhere. I think 6206-2RS is the style I have, which are double sealed unlike the stock ones. Sorry, you're among the part number experts here and I think I got you confused with hang_510 (?). Yeah, duplexes are normally used in pairs stacked against each other without any spacers, hence the need for ten or hundred thousandths in lengthwise dimensions. Apparently that's not an issue with the stub axle if everything's driven home correctly. I didn't really have a clear picture of it before this discussion and taking one apart just now. I copied this list of P/N's from the datsuns.com article on rear disc brake conversions. It seems to confirm that the bearings are plain old 6206-2RS, not duplex versions thereof: -82-83 200sx Brake Rotor: Raybestos p/n 9809, 10.125" OD -85 300zx (non turbo) rear brake rotor: Brembo p/n 3256 -Caliper Rebuild Kit: Brakeware 66427 for 200sx or Maxima Calipers, Available from Autozone -Rear stub axle lock nut (sedan only): Nissan p/n: 43262-21000, available special order from your local dealer (as of 3-05) -Rear wheel bearings (sedan only): 6206-2RS Available from any bearing supplier -Rear Stub shaft seal: Timken 224045, Available from Autozone -Porterfield R4-S Brake pads for 200sx/maxima rear calipers: AP230 -Wilwood Dynalite Single caliper: 120-4060 Edited to add...anyone know for sure that OEM peenable axle nuts are still available, like who bought them this year? I could be mis-measuring with digital calipers (don't have pitch guage) but if the pitch is really 1.25 then Datsun used a nonstandard thread. Standard pitches for M20 seem to be 2.50 (coarse) and 1.50 (fine). Link to comment
Chris#51EPGraham Posted May 27, 2010 Report Share Posted May 27, 2010 ive not heard any REAR wheel bearing failures. the set i replaced were heavily abused, & if it wasnt for all the effort pulling apart and never wanting to do it again, i would have put em back in. I've never heard of any rear WB failures either. None, ever, in the history of the world. The one very good reason for always replacing bearings in this type of assembly is that the races are likely to be damaged (brinnelled) in the process of removing them, or driving/slide hammering the stub axle out. Why tempt fate to save a few bucks when Datsun PL510 rear WB's are one of those few things we can have utter and absolute faith in? The 510 front bearings are tiny compared to 610/710 and Z cars and pretty inadequate. I autocrossed on stock 510 struts and had to readjust the bearings for every event. I also had to adjust them pretty often before that just driving a lot of street miles. Link to comment
Creepy Cruiser Posted May 27, 2010 Report Share Posted May 27, 2010 Edited to add...anyone know for sure that OEM peenable axle nuts are still available, like who bought them this year? I could be mis-measuring with digital calipers (don't have pitch guage) but if the pitch is really 1.25 then Datsun used a nonstandard thread. Standard pitches for M20 seem to be 2.50 (coarse) and 1.50 (fine). I got some last fall from the dealer, and they were still available no problem. Link to comment
Chris#51EPGraham Posted May 28, 2010 Report Share Posted May 28, 2010 I got some last fall from the dealer, and they were still available no problem. Thanks, Creepy Cruiser! That's reassuring to know since they turn out to be maybe nonstandard threading. That comes up a lot on lathe manufactured parts because lathes can cut all kinds of nonstandard threads and engineers often use them for whatever reason. Link to comment
Topher88 Posted January 14, 2012 Report Share Posted January 14, 2012 I hate to bring this back from the dead but when I talked to Nissan it said that there are an inner and outer barring and they were both different prices and all I'm seeing in this thread is one barring 6206. I havent taken apart my hubs yet so this might be a very dumb question but are there two barring in each side or just the one? Link to comment
thisismatt Posted January 14, 2012 Report Share Posted January 14, 2012 I hate to bring this back from the dead but when I talked to Nissan it said that there are an inner and outer barring and they were both different prices and all I'm seeing in this thread is one barring 6206. I havent taken apart my hubs yet so this might be a very dumb question but are there two barring in each side or just the one? No, the bearings are both the same, two per side. The 6206-2RS bearing is a double sealed bearing, whereas the originals were not sealed on the inside and thus the hub was packed with grease inbetween the two bearings. You get the 6206-2RS so you don't have to deal with grease, although it might still be advised to put some in anyways. Link to comment
Topher88 Posted January 14, 2012 Report Share Posted January 14, 2012 No, the bearings are both the same, two per side. The 6206-2RS bearing is a double sealed bearing, whereas the originals were not sealed on the inside and thus the hub was packed with grease inbetween the two bearings. You get the 6206-2RS so you don't have to deal with grease, although it might still be advised to put some in anyways. Ok cool thanks Link to comment
Topher88 Posted January 16, 2012 Report Share Posted January 16, 2012 Ok any other tips on removing the 27mm nut on the hubs?? I cut off the pinged edges but even with a 4 foot cheater bar still can't seem to budge the nut..... And they are not reversed thread right? Link to comment
thisismatt Posted January 16, 2012 Report Share Posted January 16, 2012 Correct, neither are reverse thread. Make absolutely sure you've cut away enough of the peened edges, then a quality impact wrench is your friend. Link to comment
Topher88 Posted February 13, 2012 Report Share Posted February 13, 2012 When installing a new nut just crank iit down to next week or is there a tq I should set it 2? Don't have a manual with me at this time Link to comment
thisismatt Posted February 14, 2012 Report Share Posted February 14, 2012 When installing a new nut just crank iit down to next week or is there a tq I should set it 2? Don't have a manual with me at this time From 1972 Factory Manual: Assembly and Installation: Install in the reverse order of removal, noting the following points. 1. Clean the wheel bearings, oil seal and the inside of the axle shaft housing. 2. Be sure to install single sided seal bearings correctly, seals facing outward... (Paraphrased) 3. When refitting the wheel bearing the pressure should be applied to the inner race. 4. When replacing the suspension arm, measure the dimension L1 & L2 (see fig. RA-19). The length of the distance piece [spacer found between bearings-rn] is 0.05mm (.0020 in.) shorter than the length of the housing. Example: When an axle housing is coded "B", select "B" coded distance piece. [Diagram shows a mark is located on the trailing arm and the spacer. Doesn't specify top or bottom. L1 is indicated to be the dimension from bearing shoulder to bearing shoulder, L2 is the length of the spacer.-rn] Specifications: Mark A, L1 length: 59.05-59.15mm, L2 length: 59.02-59.08mm Mark B, L1 length: 58.95-59.05mm, L2 length: 58.72-58.98mm Mark C, L1 length: 58.85-58.95mm, L2 length: 58.82-58.88mm 5. Replace wheel bearing grease every 50,000km (30,000miles). Pack wheel bearings with MP@ or MP3 grease as shown in Figure RA-18. Apply grease to the lip seal and wheel bearing. 6. Replace the wheel bearing nut after it has been used twice. Wheel Bearing Adjustment 1. After tightening the nut to a torque of 25-33 kg-m (181-239 ft-lb) check the rear axle shaft end play. It should be 0.15mm (0.006 in.) and should have a turning torque less than 7 kg-cm (6.1 in-lb). If the correct end play or turning torque cannot be obtained, disassemble and replace the distance piece. 1 Link to comment
thisismatt Posted February 14, 2012 Report Share Posted February 14, 2012 Yeah....239ft-lb! :D 1 Link to comment
Topher88 Posted February 14, 2012 Report Share Posted February 14, 2012 Yeah....239ft-lb! :D geezzzzzzz thats a shit load. thanks man ill be getting on that this week :-) Link to comment
