Pineapplegti Posted September 1, 2010 Report Share Posted September 1, 2010 Well ill get 2 sets of front coilovers when im done.. You can buy em when i get them to work :P Quote Link to comment
280zx2by2 Posted September 1, 2010 Report Share Posted September 1, 2010 Well ill get 2 sets of front coilovers when im done.. You can buy em when i get them to work :P For a CONSIDERABLE ratsun discount amiright? :D Quote Link to comment
INDY510 Posted September 1, 2010 Report Share Posted September 1, 2010 A couple questions.. Will 13x7 american racing Libres fit over zx brakes ? Most people need to run a 14" wheel.......... do you have flares? slide into a very cut down 510 shock tube that i will bolt and weld into place Are you going to use stock 510 brakes?............... 280zx brakes DO NOT fit on 510 struts..... Quote Link to comment
Pineapplegti Posted September 2, 2010 Report Share Posted September 2, 2010 Most people need to run a 14" wheel.......... do you have flares? Are you going to use stock 510 brakes?............... 280zx brakes DO NOT fit on 510 struts..... Yeah thats what i figured.. I have no need for bigger brakes.. Ill stay with the 13s.. Quote Link to comment
PurePontiacKid Posted September 8, 2010 Report Share Posted September 8, 2010 Do you realize you could shorten your 510 struts (fun with lathe), add coilovers ($200), camber plates ($180),, , and some good short shocks (tokico $130-160) That's probably true... haoever, there's arot moar to it than that though (if you wanna do it RIGHT, and have a good handling car)... I'm to the point of wishing I had gone with S13 suspension conversion on my ZX, and spent the money on Stance coilovers. going this route I think is going to end up being moar expensive than doing the S13 stuff... Koni struts................$200 exhaust flanges.........$10 (used to set coilovers on) coilovers......................$80 (yes, I used the cheap ones) new springs................$80 (stiffer to keep from bottoming out as often) NCRCA's...................$130 (befoar shipping) camber plates..........$180 ___________________ ...................................$680 And I already had the 280ZX struts and brakes (kinda hard not to when you're workin on a 280ZX lol) And that's just the front suspension! gotta do moar work to the rear still (on top of half the crap I put up there :( ) :/ Quote Link to comment
butcherboyjc Posted September 26, 2010 Report Share Posted September 26, 2010 What's the rest of that equation? I know the hubs fit just fine, but it also changes the rotor position, so IIRC, you can't use the 280 calipers when you do that. Can you just put the 300zx calipers on the 280zx struts? I know I've checked this personally, but off hand, I don't remember what the answer was.....and I don't have time to go dig through my own thread :) In The Dime Quarterly there is a write up for using the 280sx strut and swapping the 300zx hub and a caliper bracket is machined to use the willwood caliper and an 11" rotor. This setup would give the benefit of correcting the track width, larger brake rotor, four piston caliper (lighter than the oem caliper). I have seen lots of talented machinist on this forum, why doesn't any one supply this bracket to do this swap? Is there a disadvantage I am missing from this swap that I am missing? Quote Link to comment
dennis Posted September 30, 2010 Report Share Posted September 30, 2010 In The Dime Quarterly there is a write up for using the 280sx strut and swapping the 300zx hub and a caliper bracket is machined to use the willwood caliper and an 11" rotor. This setup would give the benefit of correcting the track width, larger brake rotor, four piston caliper (lighter than the oem caliper). I have seen lots of talented machinist on this forum, why doesn't any one supply this bracket to do this swap? Is there a disadvantage I am missing from this swap that I am missing? I think that is what arizonazcar.com is selling, but of course you have to buy the whole front kit. Quote Link to comment
Master-O-Turbonics Posted October 27, 2010 Report Share Posted October 27, 2010 280z is pretty: 280zx is less pretty: Look at the quarter windows and that is the fastest way to tell the differnece. Quote Link to comment
housew Posted May 27, 2014 Report Share Posted May 27, 2014 Aight, here's what I used: Koni PN#: 86 1919 fits all models of '75-'89 Rabbits and Sciroccos. and this is how they compare to Z31/S130 stuff: reds are obviously Koni's lol the upper Tokico HP's are Z31 300ZX front struts (the shorter of the blue ones) the lower Tokico HP's are S130 280ZX front struts (the longer of the blue ones) clearly an old post but this pic is super helpfull to me. if you look at the Tokico inserts, it looks like it is m12 thread at the top, then an shouldered diameter slightly smaller than the shaft diameter pretty similar to the strut inserts i have on my car. if you look at the koni inserts they look like an m12 thread at the top, and an 12mm diameter shouldered spot below the thread. I could bolt my camber plates to the koni's but not the tokico's they way they are now. Are people getting their camber plates machined, their inserts machined, or just buying the correct combinations so their stuff bolts up? can any verify or measure the diameter and length of the thin section under the threads on the konis? I think they would work and very well may be the way to go rather than having to do machine work (not scarred of that either, but if the cost is similar, new inserts is a win in my mind) Quote Link to comment
banzai510(hainz) Posted May 27, 2014 Report Share Posted May 27, 2014 T3 the guy that works there knows about the Koni insert issue. You get a bushing or somthing. or not use the busahing. I use the koni 280zx inserts but the threads(funky thread size also) to hold it in the tube are barely enough but work. call Techno Toy Tunning. I think I had to buy soem nuts as my inserts didnt come with them or lost one. Hpuse you have to remeber buying the shortest tube is not alwasy going to work. It depends on where your spring perch is also and the off set of your rims. I myself run the stock 510 struts and had to keep the perch in stock position to keep the tire hitting the perch.+25mm 15x7 rims. more towards 0 offset then you can drop the perch lower. I just went with the 7in tall spring and crank the collar all the way down Quote Link to comment
KlassicMotion Posted May 27, 2014 Report Share Posted May 27, 2014 My T3 camber plates came with three different sized bushings to use with the different inserts. Here is another link for comparison: http://community.ratsun.net/topic/39512-strut-insert-and-rear-shock-guide/ Quote Link to comment
That4doorKiD Posted January 11, 2017 Report Share Posted January 11, 2017 I used my stock 510 struts,,, then shortened them ~2 inches..... and re-threaded the top of the strut tube With a 4.5" coilover collar.... . I can put the front crossmember on the ground (I know you already commented on how low my car is,, and how you'd be worried about the tires hitting the flares) If i shorten my zx struts, will using my 4.5 inch collars be short enough if I make the perch sitting flush with the top of the strut and top of the collar. HARD TO PUT IN WORDS Basically... everyone has 7 inch collars/springs that they use for their coilovers. Thus perch is 7 inches below the gland nut or tip of the strut tube, which means more adjustability. Losing those 3 inches of adjustability with my 4 inch collar, will I still be able to slam my dime on 15s with the 4 inch collar? MR2 inserts and shortened struts. Anyone know what I am trying to say please answer my question lol. THANKS Quote Link to comment
That4doorKiD Posted January 11, 2017 Report Share Posted January 11, 2017 Or should I just lower my perch an inch or two? which would be 5-6 inches below the gland nut Quote Link to comment
Lockleaf Posted January 12, 2017 Report Share Posted January 12, 2017 The actual adjustability is meaningless. You can get just as low by just moving your perch as far down as possible as you can with an adjustable setup that lowers the spring the same distance. Lowering is about total strut height in this case. How you reduce that total strut height isnt important. Quote Link to comment
That4doorKiD Posted January 12, 2017 Report Share Posted January 12, 2017 I will be lowering my perch then. Thanks for that info! Quote Link to comment
banzai510(hainz) Posted January 12, 2017 Report Share Posted January 12, 2017 key is what offset rim/tires you use. On 510 struts I used the same perch weld on my t3 kit as the tire would hit the collar.as I had +25mm 15x7 and its almost touches the strut. on 280 zx struts being 3/4 INNER, I think you can get the collar below using a 0 offset rim 1 Quote Link to comment
q-tip Posted January 12, 2017 Report Share Posted January 12, 2017 I have +17 offset 6.5" wide wheel on the from of my 510 with zx struts and they're so close that the flex in the tire has rubbed the paint off of the strut tube. With the Zx hubs 0 offset is almost a must. Quote Link to comment
