Datto 720
This is my on going build I started 2 years ago and I wanted to show all the work over here at ratsun. Its also over at infamousnissan.com and im copying all the pics and some text from there so I hope you enjoy! DSC00104.jpg
My junk and parts
The lokar lights
  • Replies 3
This is the pedal assy I moved over about 2" . I moved where the booster mounted over so the pedel wouldnt have to be so far over. I got a 82 240sx booster thats 8" and made a plate for the fire wall. I got the reverse swing clutch master for $120 shipped and I will mod the stock pedal to it after I get it mounted. Im also goin to run a honda battery thats realy small so it will fit up front. But on with the pics.
And this is my hood that my friend joey striped for me.
I got the clutch master in and my brakes done. I had to mod both pedels for it to work but not to bad.
And a pic of the truck laid out
Got the back all done now on to the air management and cut the bed out
Got some stuff done to the ol'e datto! Got the whole truck plumbed and wired. I hard lined her from front to back not one bit of soft line! Shaved the valve cover and did some small things under the hood.
