LeDevil Posted November 30, 2007 Report Share Posted November 30, 2007 Title says it all. My Speedometer doesn't work. I replaced the gauge cluster "Thanks Meanie" and no such luck. I took off the cable from the tranny and spun it with my drill and it made the other end spin. So I was wondering if there was a gear or something in the tranny that made the cable spin that I can pull out and look at/replace. Thanks in advance Quote Link to comment
DISLEXICDIME Posted December 1, 2007 Report Share Posted December 1, 2007 the part where the cable plugs in on the tranz is the gear there is a screw or bolt right above where the cable plug's in loosen it slide the little tab over and pull it out. Quote Link to comment
