porkchopzz4 Posted April 5, 2010 Report Share Posted April 5, 2010 Hi all: I have a problem. I've got a 1971 Datsun 510 wagon. It has a mix of parts from various Dats from 1969-1983. Most of the work was done by previous owners. Therefore, every time I go to work on it, I run into a mystery. Here is the latest - I was getting some serious pinging under load - and upon testing the vacuum advance on the distributor, I found the diaphram is toast - it will hold no vacuum whatsoever. So I figure it's as simple as grabbing the # off the distributor, and cross referencing that to a model... then look up a vacuum advance for that model. The engine is an unknown L20B block with a A87 head. First problem: The distributor number is D6K8-12. If I understand correctly, that's a 6 cylinder distributor. And I can't find and reference to the -12 variation. I'm assuming this is the Hitachi part number 2nd problem: The Nissan part number is 22100-Y7001. Since Nissan dizzy part numbers start with 22100, I know this is the Nissan part number... but no reference anywhere on the Internet to a Y7001... which probably means it's been superceded, but I can't find it cross referenced to anything. 3rd problem: I don't know what year the engine is, so I can't just order a correct year distributor and start from scratch with the right one (and if I did, I wouldn't have a core so it's cost even more money). can anyone tell me what i have here? Why my L20B has a 6 cylinder distributor and if it even matters? (or I guess more accurately I have a 6 cylinder distributor body). What's my easiest and cheapest way of getting a brand new vacuum advance? Thanks! Justin www.PorkchopBMX.com Quote Link to comment
porkchopzz4 Posted April 5, 2010 Author Report Share Posted April 5, 2010 Let me answer part of my question - I found this vacuum advance part number: 22301-P7901 Supposedly this is fairly universal for these distributors - but, Courtesy is out of stock and no one else shows a cross reference for this part number. Any one know of another option? Quote Link to comment
datzenmike Posted April 5, 2010 Report Share Posted April 5, 2010 D6K8- ?? L28 dizzy for non turbo '79 and older. 22301 7900 is the closest advance for the '82 Maxima L24 motor. Quote Link to comment
hang_510 Posted April 5, 2010 Report Share Posted April 5, 2010 i have a working vacuum advance from an edizzy, yours for $$hipping. Quote Link to comment
