S130Z, Dottie
  • Replies 1.3k
I don't see how the tie rod end mod adds to steering rack travel, unless it allows the rack to travel further into the housing. I do see that it would mess with bump-steer because the steering rack is now 1" wider than it was before and the tie rod pivots are in a different position. But your suspension most likely doesn't move enough for you to even notice.
the only thing that does is allow the rack to move farther either way, the inners are still in the stock location, so no geometry whatsoever is changed (besides when it's past where it used to go, but meh lol)
that fender is so fucked up now, it's not even funny. for some reason when I redid all the lip and lower valences and shit it moved the fender closer to the tire, so I had to pull it more, so now it's go more pull on one side than the other, and a shitload of paint is chipped off that fender.. it sucks :(
