MicroMachinery Posted April 25, 2010 Report Posted April 25, 2010 So has anybody put these on their car yet? I have yet to hear a customer testimonial.. Quote
datto510 Posted April 28, 2010 Report Posted April 28, 2010 Nobody? :huh: Mine are at home waiting for me... unfortunatly I won't be home for another month! :( Quote
thisismatt Posted April 28, 2010 Report Posted April 28, 2010 Nobody? :huh: http://www.the510realm.com/viewtopic.php?f=1&t=12993&start=270#p149538 Quote
macrosshn Posted April 30, 2010 Report Posted April 30, 2010 I just needed the LCAs. I have the T3 TC rods. It will be interesting to see how compatible the two are. i would also like to know this. i already have T3 tc rods but i'm very interested in a set of these LCAs. Quote
Dime Dave Posted April 30, 2010 Author Report Posted April 30, 2010 If the pictures T3 uses are typical for their 510 part, there shouldn't be an issue. The FutoFab adjustable LCA uses the stock 510 ball joint in it's stock position on top of the LCA. The TC rod installs on top of the ball joint so using a T3 TC rod shouldn't become a problem. The only area of concern might be the ear on the FutoFab control arm where the FutoFab TC rod connects directly to the LCA. You can measure the offset on the T3 TC rod where the attaching plate is welded onto the tube. If this offset is greater than the thickness of the ball joint flange it bolts over, then there could be interference with the TC mounting ear on the FutoFab LCA depending on how close the offset is to the mounting point. If there is a problem, the ear can be removed, it is only needed to mount the FutoFab TC rods. Long answer short, the T3 TC rods will fit. If the ear on the FutoFab LCA gets in the way, it can be cut off. If you don't like the idea of cutting the LCA, return it. We will gladly refund your purchase price or cut the ear off at no charge and return it to you if you're willing to cover the shipping costs. Quote
macrosshn Posted April 30, 2010 Report Posted April 30, 2010 If you don't like the idea of cutting the LCA, return it. We will gladly refund your purchase price or cut the ear off at no charge and return it to you if you're willing to cover the shipping costs. thanks for the reply and that sounds like great customer service. Quote
h4nsm0l3m4n Posted May 1, 2010 Report Posted May 1, 2010 This might be an obvious question, but I dont have a 510 so I wouldnt know... The way the front LCA and TC rods are designed they look very similar to that of the Z cars. With the exception of the small vertical tab, do the two cars utilize the same front suspension design? Quote
Dime Dave Posted May 2, 2010 Author Report Posted May 2, 2010 This might be an obvious question, but I dont have a 510 so I wouldnt know... The way the front LCA and TC rods are designed they look very similar to that of the Z cars. With the exception of the small vertical tab, do the two cars utilize the same front suspension design? The 510 suspension is very close in design when it comes to the TC and LCA. The inner pivot on the LCA is stud mounted on the 510 and is thru bolted on the Z car. The TC rod is the same basic design and might actually fit. The test would be comparing the parts side by side. Quote
MicroMachinery Posted May 13, 2010 Report Posted May 13, 2010 Just got my pieces today. Got the LCAs along with the TC rods and boots. These look legit. Bump for a good business with awesome parts and great customer service. Thanks again, Dave! Quote
CorAce Posted July 4, 2010 Report Posted July 4, 2010 Just got my pieces today. Got the LCAs along with the TC rods and boots. These look legit. Bump for a good business with awesome parts and great customer service. Thanks again, Dave! Have you got them on the car yet? A review would be great, I’m thinking of getting a set my self. Fit, finish, function and maybe some pics on the car. Quote
MicroMachinery Posted July 6, 2010 Report Posted July 6, 2010 I have them but I haven't put them on the 510 yet. That project came to a screeching halt when I decided to do the body work and paint. Once I find a good passenger side rear corner and do some fabbing followed by paint, then I'll write a review :P Sorry man. Probably won't be for a while unless I use em on my crummy. Quote
71pl510 Posted November 6, 2010 Report Posted November 6, 2010 This looks like a great setup If I go with something like this do I still need a camber plate or can I adjust from the bottom and use stock hats. Quote
Dime Dave Posted November 11, 2010 Author Report Posted November 11, 2010 Sorry for not staying up with this thread. Yes, you can adjust camber with the lower control arms and use the stock hats. In fact FutoFab's adjustable LCA's will give you more camber adjustment than camber plates will. I will caution that if you are looking for large amounts of negative camber, you could run into fender/tire clearance issues as it moves the bottom of the strut out not the top in like plates do. If you are using FutoFab's adjustable LCA's and TC rods, always do your front suspension alignment with camber first, caster next (double check camber, adjust if needed) and then set toe-in/out. Using the LCA to adjust camber will dramatically change toe-in. Toe must be re-set everytime camber is changed. Hope this helps. Quote
paul97 Posted September 13, 2020 Report Posted September 13, 2020 Has anyone installed this set up yet? I have the kit but I am wondering if I still need to install the washers on both sides of where the lower arm bolts to the cross member. Quote
paul97 Posted September 15, 2020 Report Posted September 15, 2020 I found out that the kit does use the washers on both sides in case anyone else wants to know. I will post pictures after I install mine. Quote
scooter Posted January 24, 2021 Report Posted January 24, 2021 I have been running these for the last 5 years, still nice and tight on the rod ends and the tc arm.. i DO need to take them back off and re-polish them as they are looking pretty weathered now. if your running these on the street you gotta have the rubber boots that go on the rod ends... it keeps them pristine. Quote
Dime Dave Posted February 3, 2021 Author Report Posted February 3, 2021 (edited) I saw Paul brought back this post from the dead. @scooter Thanks for the positive feedback. I realized looking at the post, our LCA / TC Rods have gone thru some changes and we have more applications. FutoFab's current LCA and TC Rods fit the following models: 200SX (1977-1979) 240Z (1970-1973) 260Z (1974) 280Z (1975-1978) 510 (1968-1973) 610 (1973-1976) 710 (1974-1977) B210 (1974-1978) Edited February 3, 2021 by Dime Dave 1 Quote
barra Posted March 12, 2025 Report Posted March 12, 2025 Hi Dave I'm chasing castor rods with extra articulation for an airbagged 510. I was thinking heim jointed ones (apex, maddat or T3) but do your pivot balls have enough throw for my application? Quote
