kiznook Posted June 23, 2009 Author Report Share Posted June 23, 2009 HOORAY!! time to revive this thread. Gonna have to skip alot of stuff I've done and jump straight to the current. Just before canby I had BIG plans, long story short, life got in the way and all I got done was putting in a new clutch. Turned out my car had a 200mm flywheel with what looked like a 510 clutch (tiny, weak PP) Ended up switching to 225mm and running a clutch for a maxima/810 I believe, whchever one I went with had the heaviest OEM pressure plate. Clutch works great, and grabs far better than the old one ever did. SOMEONE BUY MY 6-bolt 200mm Flywheel!! Quote Link to comment
kiznook Posted June 23, 2009 Author Report Share Posted June 23, 2009 Today I pulled the ol DGV off in favor of a single 45 DCOE on a cannon manifold. The carb needs some adjustment/jetting, gotta figure out a better return spring, and need to drill the manifold and add a barb for vacuum advance. off the bat this carb runs about as good as my DGV (which wasn't very well tuned) and it deffinitley pulls harder off idle. I used a throttle cable from an F-10 and it is PERFECT for the 510, the mount at the pedal is like a master cylinder, and all you have to do is remove the ball for the old linkage from the pedal. I expect to be very happy with this setup once I get it dialed in. Pictures will be up soon. Quote Link to comment
lynchfourtwenty Posted June 23, 2009 Report Share Posted June 23, 2009 awesome man! Quote Link to comment
bonvo Posted June 23, 2009 Report Share Posted June 23, 2009 kiz you should know the rules by now pics man pics :D Quote Link to comment
kiznook Posted June 23, 2009 Author Report Share Posted June 23, 2009 sorry, took a few test runs then had to set the hood on so it wont get rained on, then I realized that I didn't take any pics. BUT on the other hand it was time for dinner so I really didn't care :D Quote Link to comment
DISLEXICDIME Posted June 23, 2009 Report Share Posted June 23, 2009 did you check the chokes yet Quote Link to comment
kiznook Posted June 23, 2009 Author Report Share Posted June 23, 2009 I did not. Where am I supposed to look? Quote Link to comment
]2eDeYe Posted June 23, 2009 Report Share Posted June 23, 2009 You could look at the pic's....wait... :D Quote Link to comment
69FJWagon Posted June 23, 2009 Report Share Posted June 23, 2009 I did not. Where am I supposed to look? if they are like Mikunis the choke size is cast into the face of it look inside the venturie of the carb the choke is were it necks down before the butterfly and the number should be visable,if the carb is stock I would say that the choke size would be around 34 or 37 but thats just a guess, depending in the work done to the engine stock should be fine. Clayton Quote Link to comment
kiznook Posted June 23, 2009 Author Report Share Posted June 23, 2009 I looked down the barrels, and didn't see any numbers, I just assumed I was looking in the wrong place, and or stupid. Judging by the way it runs so far, I doubt I'll need to change anything other than the jets, and settings. I really think I'm being held back by shitty timing too, but I never got around to installing provisions for a timing light (sawtooth) That'll be the next step. Quote Link to comment
kiznook Posted June 23, 2009 Author Report Share Posted June 23, 2009 Okay, from what I've been reading, you can't drill the manifold for vacuum to advance the dizzy. I had a feeling. Turns out it needs to be carb vacuum, from right around the butterflies somewhere (if I'm comprehending properly) SO, looks like I need to see if I cant squeeze some more initial advance out of it, try to get the carb dialed in, then have my dizzy recurved. Quote Link to comment
DISLEXICDIME Posted June 23, 2009 Report Share Posted June 23, 2009 i have to do the same thing steve says he knows a guy that can re curve Quote Link to comment
kiznook Posted June 24, 2009 Author Report Share Posted June 24, 2009 Dan Hart can do it. He's out there kinda by John's Quote Link to comment
kiznook Posted July 26, 2009 Author Report Share Posted July 26, 2009 Small update: This went on Then came this Now this: I ordered the rings, and have all the bearings and gaskets. Just need to get it torn apart, and as soon as the rings and the piston (Thanks DatzenMike!!) get here I'll be able to get her back on the road. On of the bolts for the flywheel is all buggered up in the crank, so I might have to take it to the machine shop. Quote Link to comment
Curt_pnw Posted July 29, 2009 Report Share Posted July 29, 2009 haha I want to move more north :D I want to go to school so bad!! Move to lynnwood or everett, etc. most of the community colleges up here are pretty good. Sorry for the thread jack, carry on. :D Quote Link to comment
72240z Posted July 29, 2009 Report Share Posted July 29, 2009 I was sorry to hear about that in the for sale thread for the carb. I hope your in the position to bounce back and continue soon. Quote Link to comment
kiznook Posted July 29, 2009 Author Report Share Posted July 29, 2009 Got it on the engine stand and pulled the pan. everything looks okay, but that's not saying much without seeing the bearings. I did take a look under the con-rod cap for #1 and the bearing looks fine, obviously not new, but no unusual wear. Fingers crossed that they all look good. Decided to quit for the night when I couldn't get the timing cover off. Need to get my hands on a rubber mallet, or dead-blow little lady just needs a love tap or two :D Quote Link to comment
kiznook Posted September 22, 2009 Author Report Share Posted September 22, 2009 Fast forward to today Long story short, finally got a piston the week before last, and I've been busting ass on it every chance I get (okay, not really, but it's been going quickly) Today I joined the assembled head with the assembled short block and worked a lot on cleaning and polishing the front cover and a few pieces here and there. If it weren't for all the cleaning, this would go quite a bit faster. I'm hoping to be back on the road within a week, maybe even by this weekend! Quote Link to comment
lynchfourtwenty Posted September 22, 2009 Report Share Posted September 22, 2009 you should try to bust ass an bring it to pir on friday Quote Link to comment
Bleach Posted September 22, 2009 Report Share Posted September 22, 2009 were's the turbo?! :D looks good. Quote Link to comment
Charlie69 Posted September 22, 2009 Report Share Posted September 22, 2009 sorry, took a few test runs then had to set the hood on so it wont get rained on, then I realized that I didn't take any pics. BUT on the other hand it was time for dinner so I really didn't care :D Now there is honesty.:cool: Glad to here it going good. Quote Link to comment
sdsurf Posted September 22, 2009 Report Share Posted September 22, 2009 You surf in Vancouver? That is ballsy!!!! Well, it has begun finally, that is to say I got my garage clean enough to get it in and have some room to work. The lame part is, as I was cleaning it started to feel like cleaning was the project, when in reality I wasn't even close to starting THE project. On with the pics: More to come as the days go by. Pleanty will be done including engine work, suspension, brakes, minor interior, wheels/tires. STAY TUNED Quote Link to comment
kiznook Posted September 22, 2009 Author Report Share Posted September 22, 2009 Northern Oregon actually, but it's been a long time. Quote Link to comment
izzo Posted September 22, 2009 Report Share Posted September 22, 2009 Northern Oregon actually, but it's been a long time. where at kiz? a lot of ppl down here in seaside go surfing, at a place called the Couve. Near Tillamook head. Quote Link to comment
sdsurf Posted September 22, 2009 Report Share Posted September 22, 2009 I surfed northern CA and a little southern OR when I went to Humboldt, but I am sticking to the warmer water now... Quote Link to comment
