Chris Haines Posted March 18, 2010 Report Share Posted March 18, 2010 i have headlights, brake lights, runnin lights left side turn signal front and back no right side turn signal(front or back). but all four corners flash when my hazards are on. would it be the switch in my column. i pulled the steering wheel off and i cant see anything physicaly wrong with it when i flip the turn signal switch from left to right. it looks to be doin what its suppose to. i can hear the relay click one time then nothin. ideas anyone? Quote Link to comment
banzai510(hainz) Posted March 18, 2010 Report Share Posted March 18, 2010 I would ck the bulbs anyway Try ohming out the turn sig switch at the connector. Maybe repluging it back in will fix it(corrossion) i can hear the relay click one time then nothin.???????????? swap the blinker cans Quote Link to comment
banzai510(hainz) Posted March 18, 2010 Report Share Posted March 18, 2010 I might not know what the fuck Im talking about. If left works then the right doesnt. both should not work as they go thru one Can. Quote Link to comment
Chris Haines Posted March 18, 2010 Author Report Share Posted March 18, 2010 thats why i think/thought maybe its in the switch. im confused on what it can be. Quote Link to comment
datsunaholic Posted March 18, 2010 Report Share Posted March 18, 2010 The switch could very well be the issue, though it could also be in the wiring. Quote Link to comment
desert_gold_hound Posted March 18, 2010 Report Share Posted March 18, 2010 Check your continuity as you switch the switch. If you have it then continue too check the rest of the wiring. Quote Link to comment
Chris Haines Posted March 19, 2010 Author Report Share Posted March 19, 2010 thank you i will try that. Quote Link to comment
fisch Posted March 19, 2010 Report Share Posted March 19, 2010 I know it is simple, but did you clean the switch? Mine was acting funny, but it looked fine, but after I hit it with sandpaper it worked fine. Quote Link to comment
yello620 Posted March 19, 2010 Report Share Posted March 19, 2010 I have seen failing blinker cans that will work properly in one direction and not the other. It is possible for the can to be the problem. Quote Link to comment
