Spades Posted March 11, 2010 Report Share Posted March 11, 2010 We have been slowly working on my boss' 68 roadster, and we started on the body. under several inches of cracked bondo, we found hacked and cut sheet metal bent outwards, with tons of bondo piled on top to make the flares. I am wondering if anyone makes fiberglass fender flares, either specifically for a roadster or that can be modified to fit a roadster. If I can find some flares, I will either weld or solder the sheetmetal back and then use a fiberglass flare. I did a quick search on google but did not turn up anything. Thank you in advance for your time and help! Quote Link to comment
ariascarlos1990 Posted March 11, 2010 Report Share Posted March 11, 2010 wonder if the Z flares would work..? 1 Quote Link to comment
banzai510(hainz) Posted March 11, 2010 Report Share Posted March 11, 2010 I have never order from these guys, but they had a photo of some huge flares on a roadster/ Might need soem big ROTAs(wheels) to make it fit right http://www.prodbodies.com/datsun.html Quote Link to comment
Spades Posted March 11, 2010 Author Report Share Posted March 11, 2010 Big wheels won't be a problem, he had spacers machined to make a set of 17"s with low profiles tuck under it. I will check that website out. Quote Link to comment
Dime Dave Posted March 11, 2010 Report Share Posted March 11, 2010 Also try Joe Harlan at Top Tech Racing in Portland, OR. He has flare molds that are nearly full panels like used on many of the SCCA Production Roadsters. toptechracing@yahoo.com Quote Link to comment
JDM510 Posted March 13, 2010 Report Share Posted March 13, 2010 heres a bad ass roadster with flares, http://beeoneoneoh.wordpress.com/2009/08/10/red-roadster-red-roadster/ Quote Link to comment
FoxyRoadster Posted March 13, 2010 Report Share Posted March 13, 2010 wonder if the Z flares would work..? You can use them but personally I don't think they fit very well. Quote Link to comment
Steb Posted March 16, 2010 Report Share Posted March 16, 2010 We have been slowly working on my boss' 68 roadster, and we started on the body. under several inches of cracked bondo, we found hacked and cut sheet metal bent outwards, with tons of bondo piled on top to make the flares. I am wondering if anyone makes fiberglass fender flares, either specifically for a roadster or that can be modified to fit a roadster. If I can find some flares, I will either weld or solder the sheetmetal back and then use a fiberglass flare. I did a quick search on google but did not turn up anything. Thank you in advance for your time and help! Spade, Are you a member of the Roadster forum? I'm sure there is someone who can help you if you join. Here's the link: datsun-roadsters@autox.team.net Steve Harvey Milwaukee Quote Link to comment
ariascarlos1990 Posted March 16, 2010 Report Share Posted March 16, 2010 You can use them but personally I don't think they fit very well. True. Now that I look at it. Quote Link to comment
FoxyRoadster Posted March 16, 2010 Report Share Posted March 16, 2010 True. Now that I look at it. My solution for it is to take a set of 4 and cut them in to make a set that are just a bit bigger, working on it currently still. A few suggest using MG flares or vw bug fenders. Quote Link to comment
ppeters914 Posted March 16, 2010 Report Share Posted March 16, 2010 Discussed several times on the 311s.org forums. Search there. Quote Link to comment
Spades Posted March 17, 2010 Author Report Share Posted March 17, 2010 Discussed several times on the 311s.org forums. Search there. Sorry I did not search there...I guess that's cause I don't own a roadster so I never go there, I do hope you don't mind me cluttering your forum here...I just needed a quick couple links to some after market fenders. I suppose if the moderators find this a useless topic they will lock it. I do appreciate those who replied, I have a few companies to check out, thank you again! Quote Link to comment
ppeters914 Posted March 17, 2010 Report Share Posted March 17, 2010 No big deal. Always amazed when folks ask roadster questions without checking the roadster mailing list or 311s.org forums. If you Google on "Datsun roadster", 311s.org is the third or fourth result. Quote Link to comment
FoxyRoadster Posted March 17, 2010 Report Share Posted March 17, 2010 No big deal. Always amazed when folks ask roadster questions without checking the roadster mailing list or 311s.org forums. If you Google on "Datsun roadster", 311s.org is the third or fourth result. I think there are a few of them that aren't on either lol though they are pretty easy to find. Quote Link to comment
freaky510 Posted March 26, 2010 Report Share Posted March 26, 2010 i just got a flyer and they are some on sale SALE! Fiberglass ZG Flare Kit, 70-78 Z Code:50-1562 Price: $199.95 http://www.thezstore.com/page/TZS/PROD/50-1563 Quote Link to comment
dbrick Posted April 13, 2010 Report Share Posted April 13, 2010 A few things work for the rears, stock front fender lips from a late car, and Dodge Omni fender lips,detailed on 311's.org or mine are cut, flared and glassed Quote Link to comment
FoxyRoadster Posted April 13, 2010 Report Share Posted April 13, 2010 A few things work for the rears, stock front fender lips from a late car, and Dodge Omni fender lips,detailed on 311's.org or mine are cut, flared and glassed only problem is finding an omni that hasnt rusted away Quote Link to comment
bonvo Posted April 14, 2010 Report Share Posted April 14, 2010 pm hyphy on here ive seen how his metalwork turned out on his flares he may have some tips for ya Quote Link to comment
Tacomaboy Posted May 22, 2010 Report Share Posted May 22, 2010 Now that is a flare. Totally awsome work! Quote Link to comment
