jeepinjakear15 Posted March 10, 2010 Report Share Posted March 10, 2010 After searching and wondering what to do about my rear tail lights I came up with a solution. My original tail lights did not come with lenses and i like LEDs anyway, I thought about building a "farmer style" bumper and putting lights in it but that would be out of place. I did not want to cut the original tail light buckets off because I didn't want to do anything that the next guy could convert back to stock. so this is what I came up with.....\ I drove down to western Peterbilt and bought some brackets and maxima oval 60 LED units http://farm5.static.flickr.com/4026/4422958796_410b7b9e4b.jpg bought the bracket for $4.90 and started to modify I cut the top edge off like this http://farm5.static.flickr.com/4060/4422192783_40d222537b.jpg I also had to drill the holes in the bracket a tad bigger Then I went and unbolted the light assembly http://farm5.static.flickr.com/4058/4422192883_14f8f32a17.jpg http://farm5.static.flickr.com/4013/4422192691_9a60e4b9fc.jpg after I got the assembly out of there i tried out the piece the bolts are three inch so they will go through all the way to the other side. http://farm3.static.flickr.com/2696/4422958518_809644e557.jpg http://farm3.static.flickr.com/2738/4422958436_cf1e8beb38.jpg had to drill some extra holes in the original bucket but you wont really be able to see them and it doesn't interfere with putting it back to stock I figured better than welding. http://farm5.static.flickr.com/4024/4422193101_c783b18d44.jpg you can see the two extra hole on the outer edges of the inside of the bucket. now to see how the light will fit looks good! http://farm3.static.flickr.com/2748/4422958770_eefa16c627.jpg lighting up! http://farm5.static.flickr.com/4023/4422193063_21ba09461c.jpg side by side comparison http://farm5.static.flickr.com/4069/4422958590_5099ed9505.jpg both in place http://farm5.static.flickr.com/4055/4422958470_f5c7c7fb11.jpg they aren"t set in stone yet but theres lots of adjustment with the bigger holes i drilled. I hope this helps somebody I thing its a great solution and a brighter one! The LEDS were 25 dollars a piece so providing you have Bolts, tools, paint, etc at home its about a $60 dollar upgrade! Quote Link to comment
jeepinjakear15 Posted March 10, 2010 Author Report Share Posted March 10, 2010 hmm dont know why the pics dont work i grabbed the html Quote Link to comment
420n620 Posted March 10, 2010 Report Share Posted March 10, 2010 you need the IMG code to transfer them over. :blink: Quote Link to comment
jeepinjakear15 Posted March 10, 2010 Author Report Share Posted March 10, 2010 Has anyone transferred pics from flickr how is this done? I don't know what is meant by I'm code as I look in the code there's the IMg src was the one Quote Link to comment
zerow Posted March 10, 2010 Report Share Posted March 10, 2010 I don't even own a 320, and I want to see how this turned out... :angry: Quote Link to comment
AZhitman Posted March 10, 2010 Report Share Posted March 10, 2010 You picked the wrong code off PB. You need the one that begins with . Quote Link to comment
jeepinjakear15 Posted March 10, 2010 Author Report Share Posted March 10, 2010 still couldnt get them to work so i linked them sorry Quote Link to comment
ppeters914 Posted March 11, 2010 Report Share Posted March 11, 2010 This is me not being an a$$h!e. Reposting using IMG tags instead of URL tags: After searching and wondering what to do about my rear tail lights I came up with a solution. My original tail lights did not come with lenses and i like LEDs anyway, I thought about building a "farmer style" bumper and putting lights in it but that would be out of place. I did not want to cut the original tail light buckets off because I didn't want to do anything that the next guy could convert back to stock. so this is what I came up with.....\ I drove down to western Peterbilt and bought some brackets and maxima oval 60 LED units bought the bracket for $4.90 and started to modify I cut the top edge off like this I also had to drill the holes in the bracket a tad bigger Then I went and unbolted the light assembly after I got the assembly out of there i tried out the piece the bolts are three inch so they will go through all the way to the other side. had to drill some extra holes in the original bucket but you wont really be able to see them and it doesn't interfere with putting it back to stock I figured better than welding. you can see the two extra hole on the outer edges of the inside of the bucket. now to see how the light will fit looks good! lighting up! side by side comparison both in place they aren"t set in stone yet but theres lots of adjustment with the bigger holes i drilled. I hope this helps somebody I thing its a great solution and a brighter one! The LEDS were 25 dollars a piece so providing you have Bolts, tools, paint, etc at home its about a $60 dollar upgrade! Quote Link to comment
jeepinjakear15 Posted March 12, 2010 Author Report Share Posted March 12, 2010 Thank you your not an a hole your a god like figure hope you enjoy the writeup Quote Link to comment
zerow Posted March 12, 2010 Report Share Posted March 12, 2010 Now that looks great! And way to go ppeters914 for handling the IMG code to make it happen :thumbup: Quote Link to comment
SurgeL320 Posted April 5, 2010 Report Share Posted April 5, 2010 This mod is so good i MUST do it to my truck. Did the brackets come with the lights together as one piece and was the wiring pretty easy ? Do they work as turm signals also or is that separate? Quote Link to comment
SurgeL320 Posted May 6, 2010 Report Share Posted May 6, 2010 I did my own lights after seeing your post . check it out this page of my build thread. http://community.ratsun.net/topic/12007-surge-l320-progress/page__st__60__gopid__300043entry300043 . But i gotta say thanks to jeepingjakear for the motivation Quote Link to comment
