PtheDude Posted November 21, 2007 Report Share Posted November 21, 2007 Gents, Is it worth the obvious hassle of pulling my 75 rear and replacing it with my 79? Is the difference hugely significant? Is it hell breaking those 25-29mm bolts? Quote Link to comment
datzenmike Posted November 21, 2007 Report Share Posted November 21, 2007 The '79 is a 4.11 gear isn't it? What 29mm bolts are you talking about? Quote Link to comment
]2eDeYe Posted November 21, 2007 Report Share Posted November 21, 2007 Shouldn't be any 25-29mm bolts that need breaking to swap rears. The 79 rear axle is supposedly 1.5"s wider than the 75 axle. The 75 makes it easier to tuck your wheels when lowering and gives you a better turning radius. The 79 rear will be minimally more stable. As Mike stated the 79 may have 4:11 gears while the 75 will have 4:375 gears. You could just swap the third member if you want the 4:11 gear ratio and keep your turning radius. See ya Saturday :D Quote Link to comment
PtheDude Posted November 22, 2007 Author Report Share Posted November 22, 2007 by the bolts I mean the badboys at the end of the leaf springs. third member? sorry, noob. Saturday is still good, I'll be here. Quote Link to comment
]2eDeYe Posted November 22, 2007 Report Share Posted November 22, 2007 You may need to double wrench those bolts to crack them loose...or a big ass breaker bar. The third member holds the ring and pinion, it's also known as the differential. It's in the center of the axle and the driveshaft is bolted to it at the pinion flange. If you unbolt the axles (4 17 mm bolts per side behind the brake drums) and slide them out a bit, you'll feel the come out of the side gears. Then you can unbolt the third member (about 10 12mm nuts) Then you 'll need to pry it out of the axle housing. It's kind of a heavy pig so be prepared. Is your 75 rear making noise? Quote Link to comment
