Datsunville finishing lost 1969 2 door project
  • Replies 342
Gas door mod check
Stuff you need off of random Nissans
Grind off the little nipple
Drill a hole
Make the hole square
Install this, with a clip. Maxima
Weld the striker from a 300zx gas door. There ez to remove at the JY, 2 tiny spot welds (hammer and a screw driver)
You will also want to get the spring that mounts to you hinge with the screw that holds the gas door on. Look close.
Done
You can do the full cable but it is a pain in the ass I have done it a few time. Lately I just cut the cable and leave myself a foot. then run a popper.
  • Like 3
