the510keeper Posted August 8, 2012 Author Report Share Posted August 8, 2012 Skib go tthe mud work done And I Glued the lower valance on with sems 2 part seamseal Next step reprime the complete car and allow to bake in the sun for a few days Quote Link to comment
Ranman72 Posted August 8, 2012 Report Share Posted August 8, 2012 mmmmmmmmmmmmmmmmmmmmmmmmmmmm looks like you've done bluebird tail lights before Quote Link to comment
the510keeper Posted August 8, 2012 Author Report Share Posted August 8, 2012 This is what I do this is the first car I did BB taillights on, White Knight 2nd Eddies 2 door MIA 1 Quote Link to comment
jrock4224 Posted August 8, 2012 Report Share Posted August 8, 2012 mmmmm nice work james .....104 is work stoppage heat....here at the shop we drag the frsh air pump in the air condtioned bathroom ... its so nice a cool inside the helmet......i like to fart bomb the fresh air pump when my blaster is being a whiner too.... wish goons had cool option tails like that...all i get is a lread lense .... then i took and am making the reverse lights foul weather lights....euro trick to keep people from rearending u in the rain... its too bad they don't make a idiot texting light bu not sure how that would work... Quote Link to comment
Tristin Posted August 8, 2012 Report Share Posted August 8, 2012 Work looks fantastic. What's a ballpark figure for this kind of paint and metalwork? Does the price include inn fare (aka your couch) for those that come out of state for paint services? :D Quote Link to comment
the510keeper Posted August 8, 2012 Author Report Share Posted August 8, 2012 For those that come from out of state. We do a work off your room and board. I run a painting business (houses commercial building etc) so I don't have the time necessary to do the work. So i rely on helpers. That would be you, I will teach you and you work on our projects and your project. I do over see everything and sometimes thing get to be done twice. I will also do the more tecnical areas of auto body and paint. ie painting, buffing, etc. I rely on helper for the sanding (once I teach them how to sand) On with more pics Besides the taillight panel this is the 3rd priming. The taillight panel will need to be completely sanded and primed again.. We not installing bluebird taillights we are installing 710 taillights custom and has never been done before Quote Link to comment
jrock4224 Posted August 8, 2012 Report Share Posted August 8, 2012 i don't think skib is planning on leaving....he is in every pictoral banging out work....sun baked solvents in the morning....mmmmmm...something we cant do to often here in washington Quote Link to comment
the510keeper Posted August 8, 2012 Author Report Share Posted August 8, 2012 Skibs leaving he just needs to get his car done Jer's is first Quote Link to comment
the510keeper Posted August 22, 2012 Author Report Share Posted August 22, 2012 Jamb in yo Quote Link to comment
blueridgespeed Posted August 23, 2012 Report Share Posted August 23, 2012 I've seen more than a few hoods (and roof skins) where the factory adhesive "blobs" have given up after all the years (and dings). It appears you've replaced with new. Did you use a standard seam filler or a specific adhesive? FUSOR seems to be popular around here and I've used it without complaint but do so little work I have to get a new tube each time and they aren't cheap. Haven't found any way yet to cut cost on a good paint prep and paint job...but still searching - please advise, keeper! Also, I see an excellent and masking-intensive jamb job here. Is the gray we see an epoxy used as a sealer and then immediately covered with color/finish paint? PPG's DP stuff works this way - but it can't set too long or else its HELL to sand. Nice to get two "stages" (sealer and color) out of one masking - if that's what's happening here. Do you really train painters? If so, that must be the only appropriate punishment for all the folks who ask you to paint their cars! Brilliant! Quote Link to comment
the510keeper Posted August 23, 2012 Author Report Share Posted August 23, 2012 I love questions like these Yes it is DP40LF, usually seal with out thinning 2:1, wait 18- 24 hours light scuff and base/clear DP40 is the best and have not found better SEMs seam sealer 2 part component, works great. ($25 a kit, we have 6+ kits in this car) The tubes wont expire but you have to replace the tip every time. This hood skin was fucked. if you tried to block it. The skin would move 1/4er of an inch in and out (not good) So we 2 part panel boned the front area with clamps and then 2 part seam sealed the remaining frame to the skin, hoping to keep in in place while longgggg boarding. Tomorrow is color day. It's to hot here after 12 noon to spray paint. No wind, low dust etc in the morning to spray base clear. I thin k it would be cool to teach auto body, but no time for schooling to get the required paper work. So we teach Datsun heads alittle about making their cars look good and helping us get our cars done. Nobody knows it is punishment til there here. Ha ha ha ha 1 Quote Link to comment
Skib Posted August 23, 2012 Report Share Posted August 23, 2012 Nice to get two "stages" (sealer and color) out of one masking - if that's what's happening here...... If so, that must be the only appropriate punishment ..... I masked that car for fuckin hoooours :rofl: Quote Link to comment
jrock4224 Posted August 23, 2012 Report Share Posted August 23, 2012 hey james do u miss the old original purple can dp product from ppg.....i stock piled a bunch before i quit at the jobber i worked for..... i thought the lf sprayed heavy ... layed out rough and always seemed to stay rubbery.( like water bourne..)....i could get it to lay down better .... with dt870 but it would lay out even smoother with a hotter reducer but i was so bad waiting for the hotter reducer to flash off and would always put a hanger somewhere i thought was drier than it really was...up here i had to force the store i worked for to order in 885 or 895...being ppg didnt think our area warranted hot weather reducers. for everyone infos... james uses top of the line products ....dp is not cheap and there's cheaper alternatives but i have really only seen james using stuff that is considered high end materials....its nice to know cause theres a lot of painters up here that would charge u for using top shelf stuff then going and buying all aftermarkets .to increase there profit.. which aftermarkets aren't bad products and arer much cheaper but theres not real factory backing if something should go wrong....nice to see someone not willing to sacrifice there product over a few bucks that u will utlitmately spend ten fold redoing it, kudos to the keeper 1 Quote Link to comment
philcas1987 Posted August 28, 2012 Report Share Posted August 28, 2012 haha total punishment Quote Link to comment
Z chopper Posted August 30, 2012 Report Share Posted August 30, 2012 haha total punishment ya but in a good way :rofl: Quote Link to comment
the510keeper Posted September 2, 2012 Author Report Share Posted September 2, 2012 jambs are done and look great Most the parts are final sanded thanks to Skibs hard work. Just dealing with hood and trunk lid now ready for primer one last coat (incase you guys and gals were not counting this is the 3rd time this bitch has been blocked and yes we have to do it one more time) fucking hate trunk lids. tell ur bitch to get her fat ass off the trunk of my car. can you see the pencil marks, that is from the seam sealer leaving high spots in the skin, small price to pay for a hood that does not flap in the wind. flap flap flap And ready to block again the 15 is for 150 grit blocking with all the random Datsun 510 parts it get confusing Might have to take this boy to Victory and beyond Sand sand sand my darling don't maunder a single word 2 Quote Link to comment
RedBanner Posted September 2, 2012 Report Share Posted September 2, 2012 ill be seein you........ Quote Link to comment
Draker Posted September 3, 2012 Report Share Posted September 3, 2012 I love the color. This thing is going to look so bad ass! Great work as usual! Quote Link to comment
Ranman72 Posted September 3, 2012 Report Share Posted September 3, 2012 this looks great my friggen arms are tired of seeing how much you guys sand This color is going to be bitchen the engine bay looks fantastic when are you spray the car I want to come see it after its sprayed Quote Link to comment
sssr20det510 Posted September 7, 2012 Report Share Posted September 7, 2012 Looking good now get to sanding LOL Quote Link to comment
Busta Nut Posted September 8, 2012 Report Share Posted September 8, 2012 For those that come from out of state. We do a work off your room and board. I run a painting business (houses commercial building etc) so I don't have the time necessary to do the work. So i rely on helpers. That would be you, I will teach you and you work on our projects and your project. I do over see everything and sometimes thing get to be done twice. I will also do the more tecnical areas of auto body and paint. ie painting, buffing, etc. I rely on helper for the sanding (once I teach them how to sand) Are you saying you are willing to train for free?? I have one to two Saturdays a month available. It's mot much but I would love to learn body work, just don't have time for classes. Don't even have to learn on my car. I'll just come help you! Quote Link to comment
