Trans adapter
mklotz70
Bre620 and I started on this project this last weekend. He wanted to work on my projects, but I'm burned out and bored with most of mine. This was different and it's something I looked into a year or two ago. Not sure when we'll finish it....if we even finish it. We probably will finish it, just not in a big hurry to. Thought I'd share what we've done so far in case it can help someone else.
Basically, I turned an adapter to center the plate. This allowed us to create the plexi pattern. It's not accurate enough to use as a template, but it quickly/easily let us see if things lined up and would fit. The biggest challenge will be to get the starter position moved a bit and working with the smaller E1/J13 flywheel. We still need to compare trannies and clutches to see if they're going to stop us....the plate is the easy part :)
  • Replies 6
  • 2 years later...
