Help identifying cam
papasmurf
So I just got a chance to look over the new engine I got for my Z. It's an l28 with an n42 head and the cam shaft is not stock. Yay maybe it's better maybe I scored big time well I don't know yet because I can't for the life of me figure out who made it and what it's specs are. So here are the clues I have gathered so far:
has stamped on it between the lobes "D2" and "CWC" on the end what I can only assume is the grind number is "686".
Google has turned up nothing, I posted on hybridz and have yet to recieve a good answer so I'm turning to you. Be my detectives crack the case guys. I wanna find out some specs and know wether or not I scored here and if it's worth using this cam over the stock.
  • Replies 4
I believe that the "cwc" is a Schneider brand cam and might be a regrind and not a new cam. contact schneider and give them the #. they will give you the specs.
if it is a regrind. you will have to. No Exceptions. use a degree wheel to install it correctly. Regrinds can be 10-12 degrees off from factory spec and sometimes {most of the time} need an adjustable cam sprocket to get the cam timing perfect. my personal experiances.
peace
tc
I have a schneider and a Webcamshaft
both have CWC on there so maybe is a Master casting from one company.
Comp cams
elgin
Isky (dont think theres has a CWC but never seen a new one up close)
sometimes its kinda hard to search their websites and figure this out
I didnt know Elgin and Comp cams still made nissan camshfts myself.
Most others are regrinds. who know?????????
Basic is measure with a caliper the lobe then measure 90 deg to get lobe lift subtract the difference (be like .277 )then multiply by 1.48(1.5)
.277x1.48=.409 valve lift. this would be close to stock specs
duration ???youll need a degree wheel.
