KELMO Posted March 22, 2011 Author Report Share Posted March 22, 2011 Well, like they say....you learn something new every day (crap). No, actually this is my first go around with a car and just learning as I go. Most of the spots that are rusted still haven't really been touched as I was not sure how to deal with it and have been thinking about learning how to weld. That way I can just cut it out. 1 Quote Link to comment
Rob W. Posted March 22, 2011 Report Share Posted March 22, 2011 Nice lookin ride. Its good to see another New Mexican wrenchin on an old Datsun. Keep it up. 1 Quote Link to comment
KELMO Posted March 23, 2011 Author Report Share Posted March 23, 2011 Yep, I think there are 4 maybe 5 of us Neuvo Mexicanos on here :cool: I had to get a map to figure out where your at 1 Quote Link to comment
Rob W. Posted March 23, 2011 Report Share Posted March 23, 2011 Yep, I think there are 4 maybe 5 of us Neuvo Mexicanos on here :cool: I had to get a map to figure out where your at I'm surprised you found it on the map it doesn't make it onto most and google and the rest locate 4 miles up the road. I still have a lott of family in Burque maybe I'll look you up next time I'm down there. Keep wrenchin! 1 Quote Link to comment
KELMO Posted March 24, 2011 Author Report Share Posted March 24, 2011 Shoot me a PM next time your headed down and we'll see if we can catch each other. 1 Quote Link to comment
patra_is_here Posted March 24, 2011 Report Share Posted March 24, 2011 Well, like they say....you learn something new every day (crap). No, actually this is my first go around with a car and just learning as I go. Most of the spots that are rusted still haven't really been touched as I was not sure how to deal with it and have been thinking about learning how to weld. That way I can just cut it out. automotive paint supply shops carry "stop rust" paint. comes in quarts and you just brush it on. same this as eastwoods 'rust encapsulater' and similar to POR 15 (which is thicker). depending on what you're painting, it helps to thin the paint out a little bit so it'll brush on better. If you are painting something that is really smooth, you might want to experience a couple times on similar items to find the right amount to thin the paint down. the stuff works great for painting over surface rust. I treated the engine bay and rear subframe to like 2 coats before actually painting it with a color. 1 Quote Link to comment
KELMO Posted March 25, 2011 Author Report Share Posted March 25, 2011 Thanks, good stuff to know. The fenders, hood and doors are pretty much rust free (the hood was brand spankme new OEM so I had to paint it ;)). Its the sills and the quarters where the real issues lie. When I had the front clip switched over they also cut out floor pan rust (ok holes) and welded in new, so much of it has been addressed as far as the front half. A lot of the sanding and priming were done so it could be a daily during spring and summer. I keep it garaged and don't drive when it might rain (which out here aint very often). Its the typical project car....never gets finished and I always have something to do in the garage....where there is always beer :P 1 Quote Link to comment
fivetenguy Posted March 25, 2011 Report Share Posted March 25, 2011 Well since I had it apart, I thought I would do a mock up with the side draft webbers............ Gonna have to do something about that brake master.....maybe later. Just gonna go stock carbie If the 1200's master cylinder has the same bolt pattern as the 510, I have the solution for you: a master cylinder from Nissan Comp. It's a single reservoir that my brother purchased years ago. The car is still in the garage so it was never used. He did however put fluid and bled the brakes but that is all the use it got. Let me know if you are interested. 1 Quote Link to comment
KELMO Posted March 26, 2011 Author Report Share Posted March 26, 2011 Gonna have to drink on tha I mean think on that a little but will get back to ya I like the idea..... Still thinkin and drinkin on that but, the mount holes measure 2 7/16" inches ( give or take) and the shaft measures 2 9/16" from the flat surface where the cyl mounts to where the "u" shaped bracket for the clevis pin starts (04/03/11) 1 Quote Link to comment
KELMO Posted April 10, 2011 Author Report Share Posted April 10, 2011 So here are a couple oics of the shifter plate/boot what I started with what I cut for a plate a crappy pic of what I ended up with I had a piece of sheet metal that I cut to lay over the tunnel, cut out a round hole, put on the boot and screwed it to the tunnel. Well, I cut the hole just a little too large so that is why there are the "V" shaped pieces to hold the boot down. I will have to make another but at least I have more sheet metal to practice with ;) 1 Quote Link to comment
KELMO Posted September 5, 2011 Author Report Share Posted September 5, 2011 So, its time to replace the back glass weatherstrip. Never done anything like this before, so here it goes. First, remove chrome trim..starting with the corners Once the corners were off I slid a plastic pry bar under the outside edge to loosen them up Then used a block of wood, the plastic pry bar, and a rubber mallet. Slowly but surely tap out the straight mouldings Label all parts removed. I then used the plastic prybar to slide under the weatherstrip on the glass side and the body side then cut short pieces out Currently the glass is out ans I am prepping the opening to reinstall. The plan is to assemble the glass and weatherstrip and install as one unit.....still not sure how to do that, heard something about using a rope so we'll see what happens. More oics later just haven't gotten around to loading them up 1 Quote Link to comment
KELMO Posted October 31, 2017 Author Report Share Posted October 31, 2017 So, I am dredging this up from the deep dark depths. Ravaged this poor thing to get the green coupe ready for Williams 2016.....and then let her sit. I took almost all of the interior and quite a few engine bits. After a little more than a year of neglect, the missus was kind enough to point out that I have 4 Datsuns sitting in the shop and only 1 can be driven. She was then kind enough to suggest that I get off of my dead butt and on to my dying feet and get some shit done, so here is the priority list........ #3. 510 4DR Sedan, needs everything. #2. 510 Wagon, needs about half as much as the 4DR. #1. Grey 1200 coupe, needs interior, and some engine bits(see above). I am hoping to be about 2 weeks out from driving the coupe again but we all know how that usually goes. Oh, and I know.....I will get some pics going on here soon before the assignation squad is released. 1 Quote Link to comment
KELMO Posted November 1, 2017 Author Report Share Posted November 1, 2017 Took the dash out to fix ignition harness. Used someone else's idea with a sharpie to color on the dash. 1 Quote Link to comment
Charlie69 Posted November 2, 2017 Report Share Posted November 2, 2017 You have a great wife/motivator! LOL 1 Quote Link to comment
KELMO Posted November 2, 2017 Author Report Share Posted November 2, 2017 What happens when you have a boatload of black wire and some testors paint Another one of those "While I'm doing something to the car I may as well....." 1 Quote Link to comment
Charlie69 Posted November 3, 2017 Report Share Posted November 3, 2017 What happens when you have a boatload of black wire and some testors paint Man that is Ratsun!!! LOL 1 Quote Link to comment
KELMO Posted November 4, 2017 Author Report Share Posted November 4, 2017 Ha! you ain't seen nuthin yet. At some point I thought it would be a good idea to paint the T/L frame black. Now it seems it was not a good idea. Gotta figure out how to remove the paint and save the chrome. Ideas anyone? Fortunately, I have another set of tail lamps. Cleaned up a bit. Did some painting....Old guy, bad vision, shaky hands..... The other set was not very pretty but they will work fine for this car. 2 Quote Link to comment
KELMO Posted November 4, 2017 Author Report Share Posted November 4, 2017 Ready for the tail lamps. Shot of the car as she sits currently. 3 Quote Link to comment
Charlie69 Posted November 5, 2017 Report Share Posted November 5, 2017 Sorry I missed the williams run this year. I missed visiting with you and your wife. I did not get to purchase hot wheels from you this year. Do you sell Hot Wheels any where else? Quote Link to comment
KELMO Posted November 5, 2017 Author Report Share Posted November 5, 2017 Well, there is always Williams 2018..... Shoot me a PM about HW's you are looking for. 1 Quote Link to comment
KELMO Posted November 5, 2017 Author Report Share Posted November 5, 2017 Hoping that today the tail lamps can go back on. If so, I can move back to the dash and maybe finish that up. 1 Quote Link to comment
Duncan Posted November 6, 2017 Report Share Posted November 6, 2017 Kelmo, I found a real cheap product that removes spray paint from plastic parts without doing any damage to the plastic. I use it for metal as well. It's a cleaner/degreaser I buy from Smart and Final, and it costs a whopping $8.00 per gallon. So far, it has worked very well. I will throw a picture up of the jug this morning. My spray painted mirror is soaking in it as we speak... 2 Quote Link to comment
Duncan Posted November 6, 2017 Report Share Posted November 6, 2017 This is the stuff. I don't know if you have a Smart and Final grocery chain in NM, but I would imagine a similar product could be found at Walmart, Sam's, etc, etc. It's cheap and works great. My mirror had so much spray paint on it that the texture was mostly rendered flat by the paint filling it in. I put this in yesterday and pulled it out for a quick pic, and you can see the spot of paint that rubbed off just with my finger. I'm gonna leave it in for a couple of days and see how it does. 1 Quote Link to comment
KELMO Posted November 6, 2017 Author Report Share Posted November 6, 2017 Yeah, no Smart and Final here but I can see Walmart from my house. Thanks, I'll take a look see. Oh and this got done. A bit of a hack job but hey, look at the whole car(knowwhatImean). Now back to the dash, my back should be happy about that. 3 Quote Link to comment
Charlie69 Posted November 6, 2017 Report Share Posted November 6, 2017 Kelmo there are Smart and Final Stores in Phoenix. If you can not find the Smart and Final degreaser try a test part in Simple Green. 1 Quote Link to comment
