datsunfish Posted February 21, 2010 Report Share Posted February 21, 2010 Those look like they would function similar to these mikuni bmw boat carbs i have. No venturi or piston,just throttle plate and direct fuel spray. I got laughed at by the thought of trying boat carbs. I dont know anything about these or yours but if yours work I bet these would too with some tweaking. Quote Link to comment
Logical1 Posted February 22, 2010 Report Share Posted February 22, 2010 yes I would like to see photos of the cable linkage instead of the rod, as I never seen a SU set up using a cable.(most if I saw were Hoky) Simple and EZ is what I like.(fix it on the side of the road) Here is where a L motor shines. I picked up a cheap stainless jet ski throttle cable on ebay ($15) Link and mounted them up to my SU's. It's not amazingly gorgeous but it works perfectly and feels great! I welded a little 'T' out of some square steel tubing. Drilled 2 holes to hold on to my exhaust manifold and one slightly angled upwards for the elbow of the throttle cable. I used the end with the large 'nub' to pull down on my spindle. Fished the cable through the spindle lever and down into the elbow. I then pulled my pedal out and drilled several holes at regular increments so I can adjust the amount of 'pull' Drilled a hole in my firewall relative to those holes pulled the cable through tested which whole I liked the feel of best and used these little cable clamps that are steel circles with set-screws to lock off the cable on my pedal arm. Just for extra safety I did nico Swage after the cable clamps, not pretty but its HARD to pull off a swage down by your pedal alone! Been working smooth for 5 months now :cool: Quote Link to comment
banzai510(hainz) Posted February 22, 2010 Report Share Posted February 22, 2010 I like Imtb's set up i still have a bar linkage soemwhere at home. Logical The part ZI dont like is the sharp bend. Over time it drags and hard to return to zero undless you have a huge spring on there. Quote Link to comment
aappeexx Posted April 20, 2010 Report Share Posted April 20, 2010 Any updates to the new carbs,pics,dyno's,comments??? Quote Link to comment
banzai510(hainz) Posted April 20, 2010 Report Share Posted April 20, 2010 He did a Cam change. he said he needed more Low RPM torq. Maybe the carbs are to big? he said he put a 440 lift cam and goes better than the 475lift cam that was in there. Quote Link to comment
aappeexx Posted April 20, 2010 Report Share Posted April 20, 2010 He did a Cam change. he said he needed more Low RPM torq. Maybe the carbs are to big? he said he put a 440 lift cam and goes better than the 475lift cam that was in there. So what size of these carbs do you think would work with my L18 with flat top 240z pistons,W53 head,L20b cam,recurved dizzy,5 spd trans?????? Quote Link to comment
Farmer Joe Posted April 21, 2010 Report Share Posted April 21, 2010 i wonder how one of these card would run on a stock l20b? my dad ran a single 44mm SU on his courier back when i was a kid and it ran really good. and it was a 2300 that had some work done. im pretty sure one would run fine on a stock to mild engine if it wasnt revving out alot. their website said that they sell singles for like $350 with a filter. it wouldnt be hard to build a simple adapter to mount it to a stock intake... Quote Link to comment
banzai510(hainz) Posted April 21, 2010 Report Share Posted April 21, 2010 So what size of these carbs do you think would work with my L18 with flat top 240z pistons,W53 head,L20b cam,recurved dizzy,5 spd trans?????? I would pick the smaller set they sell. But maybe the SU have a advantage due to the slide helping keep up the air volicity. Some people run the Z series SU on their L motors. I myself would have picked the smaller carbs that they sell.the 42 mm kit Quote Link to comment
hang_510 Posted April 21, 2010 Report Share Posted April 21, 2010 nice setup!!! now ya got throw ANOTHER choice out there! <_< Just call me Brett Favre ... howz the ankle Mr Waffle? :P i have pulled the trigger, at least twice... $$$ and still havent decided which motor will get the ITB FI setup :mellow: Quote Link to comment
Just Joel Posted September 15, 2012 Report Share Posted September 15, 2012 Any updates on this setup? I'm looking at building a set and want to know if they are actually a decent alternative option to Hitachi su's. Did the op stick with them or end up with something different (tried to pm with no response as of yet) Thanks Joel Quote Link to comment
doomdatsun Posted September 15, 2012 Report Share Posted September 15, 2012 guys, correct me if I'm wrong, these mikuni carbs are just like direct injection ? no venturi or jets to pass through just direct air with engine vac sucking fuel as much as needed to the chambers ? Quote Link to comment
banzai510(hainz) Posted September 15, 2012 Report Share Posted September 15, 2012 You better PM IMTB I heard of customer support issues with one of these suppliers if I remeber right. also IMTB used the larger barb set when I think the smaller size would have been better for the street. These carbs have a accell pump so the response hopefully will be better than a SU. SUs dont have a accel pump. Pluse these are newer not 40 yr old junk op stick with them or end up with something different?????????? I believe he went with soemthing else as I saw a post awhile back of trying soemthing different. PM him if possible. I would like to know also. I have a SU manifold and want to try seomthing besides dual Mikunis. let us know or Pm me Quote Link to comment
Just Joel Posted September 15, 2012 Report Share Posted September 15, 2012 Tried pming imbt... No response yet ;) I have contacted the company he bought through and talked to the owner. Just want to hear what umbt's end impression was of the setup. Joel Quote Link to comment
Just Joel Posted September 16, 2012 Report Share Posted September 16, 2012 Found a thread on the realm where imbt was trying to sell his rig with mikunis still installed... Not sure if he did but I don't think we'll hear from him here. Just going to have to but a set and see how it goes. Wish the guy a v performance (dealer of said carbs) wasn't such a flake. I've found multiple forums with complaints about the company from as far back as 05' has anyone else explored this idea using other companies? Thanks Joel Quote Link to comment
Tony22 Posted June 23, 2019 Report Share Posted June 23, 2019 Mikunioz in Australia has been in business since 1985, they offer knowledgable professional service, and answer all questions . Phone or email them for advice . Using HSR's on cars they have developed their own pump nozzles , the pumps are adjustable, but the stock Accelerator pump nozzles are to large, 42's are probably more suited than 45's for 2 lt engines . i have no association with Mikunioz but in contacting them they answered all my queries . Quote Link to comment
paul97 Posted July 16, 2020 Report Share Posted July 16, 2020 Any update on this setup? I am thinking about getting a set for my L16 engine. Quote Link to comment
banzai510(hainz) Posted July 17, 2020 Report Share Posted July 17, 2020 Vintage performance has these HSR carbs set ups also Quote Link to comment
