oldsklminitrk Posted January 14, 2010 Report Share Posted January 14, 2010 Ok has anyones slave cylinder gone out on there 320?....I ask this cause mine went out today and I had to do some digging but I made something work.Basically I got one off of a 1968 520 with the a or e series engine.Then I pulled the guts out of it and cleaned it up and installed the 520 slave cylinder parts and boom it worked. 1 Quote Link to comment
fisch Posted January 14, 2010 Report Share Posted January 14, 2010 Ok has anyones slave cylinder gone out on there 320?....I ask this cause mine went out today and I had to do some digging but I made something work.Basically I got one off of a 1968 520 with the a or e series engine.Then I pulled the guts out of it and cleaned it up and installed the 520 slave cylinder parts and boom it worked. Glad to know this works! +1 Quote Link to comment
oldsklminitrk Posted January 14, 2010 Author Report Share Posted January 14, 2010 Yeah the mounting holes are different but the bore is the correct size.....so basically use it as a rebuild kit.There 18.00 dollars for the one I got and a can of cleaner and emory cloth.3/4 bore is the size. Quote Link to comment
