how to install a saturn alt
bonvo
Just did this swap and I added 1/2" outside diameter nylon sleeves to the turnbuckle eyelets.  Just drill out center for bolt and grind down to the same thickness as the eyelet.  This way eliminates most of that slop between your stock bolt size and the eyelet inside diameter.
  • 11 months later...
  • Replies 26
I have a few questions, I have been doing some research on here and I've seen some people use a later model Saturn alternator with an internal fan, I'm wondering if the setup is the same and the wiring as well, if there are any differences and you guys can give me a hand I'd greatly appreciate it, also does this modification cause the alternator to hit the idler arm? Thank you guys.
