NOOB! PCV Valve question...
LeDevil
The PCV Valve, Is it ok to have it hooked up to the breather on the Valve cover or does it have to be hooked up to the hole in the block? I noticed that the PCV sucks in and so does the block breather "hole under exhaust header" as well or should I just block off the PCV Valve hole and for get about it??? But that leaves me with what do I do with the Block breather and Valve cover breather ?? If you guys have any pictures of what you did or suggestions feel free to post them up :D Thanks in advance
  • Replies 4
