Bulletside Posted February 23, 2007 Report Share Posted February 23, 2007 Does anyone have a carborator for a '78 truck laying around? I'm getting a truck and it only needs a carb to run. It needs to run cause I'm shipping the truck and they charge extra if it doesn't run. I really would like a Weber cause that's what was on it before, but I'll take anything that will work. Thanks, -Jeff Link to comment
Cuts metal like mad Posted February 24, 2007 Report Share Posted February 24, 2007 I got one with the adapter for $150 Link to comment
Bulletside Posted February 25, 2007 Author Report Share Posted February 25, 2007 Do you know if its a working carb? Also what size are the venturi's and would I need anything else to make it work? Thanks, -Jeff Link to comment
Cuts metal like mad Posted February 26, 2007 Report Share Posted February 26, 2007 It is a plain old 32/36 DGV, manual choke, not sure what your truck comes with but you will need the 620 throttle linkage to make it work. It works fine, I got another carb thinking this one was bad... turns out my timing was off even though it looked dead on for base time, guess thats what happens when people mix and match a motor together and then sell it before finishing. Anyway, its a good carb, I thoroughly cleaned it, and found that the only thing "wrong" with it is a pin sized hole in the power valve diaphram, it works though and doesnt affect the performance that I see. "Datsun guru" Hainz says that it these thing should never need a rebuild but I would replace the diaphram if you plan on using it "long term"... but I'm a bit anal like that. Oh yeah, it needs an air cleaner but will run without it. Link to comment
Bulletside Posted February 28, 2007 Author Report Share Posted February 28, 2007 I think my truck is electric choke, but I'm not sure. Let me figure it out and I'll get back with you. I just need anything that will make it run to load and unload on a tractor trailer, preferably either cheap like an old stock one or a weber that is right for this truck. If anyone knows for sure if the manual choke would work long term or if its a bad choice please let me know. Thanks, -Jeff Link to comment
