Crashtd420 4,477 Report post Posted November 19, 2020 Yup it's pretty easy.... Quote Share this post Link to post
Crashtd420 4,477 Report post Posted November 19, 2020 That picture was using the reply window to post it.... Quote Share this post Link to post
mklotz70 3,202 Report post Posted November 20, 2020 At the bottom left of the reply window is a paperclip...drag files here or choose files. I did the choose files and it uploaded the pic onto ratsun. We weren't able to do that years ago when I was a lot more active. Loading them up to your own picture hosting site....it's hard to recommend photobucket, but they're much better right now than they have been for the last few years. There's lots of other other option. If you put them on your own hosting site, you can insert them again somewhere else anytime. I'm kinda stuck with PB since I have around 7000 pics on ratsun, all hosted on PB. Quote Share this post Link to post
Alexp521 14 Report post Posted November 21, 2020 Okay found the problem so the truck for some reason it work the way I had it wired the first time and the way I have it now like the diagram shows the problem was the green magnetic strip on the pertronix what I did was remove the green wrapper and install the parts back and then it started like a top so that was my solution thanks for all the help Quote Share this post Link to post
Crashtd420 4,477 Report post Posted November 22, 2020 13 hours ago, Alexp521 said: Okay found the problem so the truck for some reason it work the way I had it wired the first time and the way I have it now like the diagram shows the problem was the green magnetic strip on the pertronix what I did was remove the green wrapper and install the parts back and then it started like a top so that was my solution thanks for all the help Um i believe you actual do not want to remove that green tape.... I dont remember why but I remember that for some reason..... When you first installed the pertronix did you set a gap between the magnet and the pickup? 1 Quote Share this post Link to post
Crashtd420 4,477 Report post Posted November 22, 2020 (edited) From the pertronix instructions, must be in bold for a reason..... Edited November 22, 2020 by Crashtd420 Quote Share this post Link to post
Alexp521 14 Report post Posted November 22, 2020 I know I read this on the instructions but we removed it and it started right up Quote Share this post Link to post
Alexp521 14 Report post Posted November 22, 2020 This is the tape I took off and it’s from the old pertronix I didn’t want to brake the new one but it’s working now Quote Share this post Link to post
datzenmike 37,517 Report post Posted November 22, 2020 What's the point of the green tape? Is the magnet in pieces and it holds together? Is it Teflon coated in case something rubs it? Quote Share this post Link to post
Alexp521 14 Report post Posted November 22, 2020 I have no clue but that’s the only way I got spark on run when I took that tap off 1 Quote Share this post Link to post
Crashtd420 4,477 Report post Posted November 22, 2020 23 minutes ago, Alexp521 said: I have no clue but that’s the only way I got spark on run when I took that tap off I have no clue why it's there either... Well if it's working, its working... Quote Share this post Link to post
Alexp521 14 Report post Posted November 22, 2020 And one more thing by any chance dose any one know where I can buy door window regulator I know it’s off the topic Quote Share this post Link to post
Crashtd420 4,477 Report post Posted November 22, 2020 1 hour ago, Alexp521 said: And one more thing by any chance dose any one know where I can buy door window regulator I know it’s off the topic I know of a passenger window regulator that's available... I actually just bought a driverside one from the guy.... Other than that try placing a classified ad here for one... Quote Share this post Link to post
mklotz70 3,202 Report post Posted November 23, 2020 You might try contacting tdaaj ....he deals with a lot of parts. Quote Share this post Link to post
banzai510(hainz) 4,670 Report post Posted November 23, 2020 (edited) BW is ON goes to resisitor onw wire other side resisitor goes to + side coil and is the HOT Start 2 wires NEVER take the GREEN TAPE OFF!!!!!!!!!!!!!!!!!!!! this holds the magnets and if worn out the magnet stick to the dist shaft and one pulls out the Ring. Don't pull out the ring just wipe it down and I put some superglue or nail polish varnish on the tape line so it don't peel. You can get new mAGNET rINGS IF ONE FUCKS THEM UP , IF ONE ONLY GETS SPARK ON Run then you hooked up the wires wrong or the switch or the Ballast resisitor wire is wrong or fuse broke on the Black Wite wire routing This is simple fix Edited November 23, 2020 by banzai510(hainz) Quote Share this post Link to post
vicdat 39 Report post Posted November 25, 2020 There's also another way to cheaply get deecent electronic ignition spark for you old L series.....20 years ago or so I bought a Velleman K2543 Electronic Ignition Kit for like $20 (available at old electronics stores like Marvac, RadioCrack, etc)...I installed it in a small "watertight" enclosure on the firewall. If you can solder this is a super easy and fast project (remember the old Heath Kits??) It has a built-in heatsink too. This unit lasted many years in my '73 610, but was finicky if it got a little too much moisture. I replaced it eventually with the same unit, but this time I mounted it inside out of the way on the kick panel. Also - If you use a standard 4-prong trailers light connectors they can easily be made to be removed......also....if it went bad on me out on the road, it was just a simple wire change to use the points in an emergency. This is because the kit still uses the stock points but only as breakers, so they never get hot, burn, or wear out. I'd still change the points every few years anyway cause the spring will eventually weaken. Vicdat 1 Quote Share this post Link to post
Dguy210 3,293 Report post Posted November 26, 2020 (edited) 4 hours ago, vicdat said: There's also another way to cheaply get deecent electronic ignition spark for you old L series.....20 years ago or so I bought a Velleman K2543 Electronic Ignition Kit for like $20 (available at old electronics stores like Marvac, RadioCrack, etc)...I installed it in a small "watertight" enclosure on the firewall. If you can solder this is a super easy and fast project (remember the old Heath Kits??) It has a built-in heatsink too. This unit lasted many years in my '73 610, but was finicky if it got a little too much moisture. I replaced it eventually with the same unit, but this time I mounted it inside out of the way on the kick panel. Also - If you use a standard 4-prong trailers light connectors they can easily be made to be removed......also....if it went bad on me out on the road, it was just a simple wire change to use the points in an emergency. This is because the kit still uses the stock points but only as breakers, so they never get hot, burn, or wear out. I'd still change the points every few years anyway cause the spring will eventually weaken. Vicdat https://www.amazon.com/Velleman-K2543-Electronic-Transistor-Ignition/dp/B007GP6EQ6 Price: $21.95 + $5.13 shipping Edit: attached wiring diagram and parts list for general interest. 91L+BJJA0aL.pdf Edited November 26, 2020 by Dguy210 Quote Share this post Link to post
datzenmike 37,517 Report post Posted November 26, 2020 Had one of these on my 4 year old '64 Dodge. When the points close the 12 v is converted into a square wave. This is run through a step up transformer to 400v and charges up a capacitor. When the points open the 400v is fired through the stock coil for a higher output. I think it was around $50 in the day, about a weeks pay. Quote Share this post Link to post
Alexp521 14 Report post Posted November 26, 2020 Thanks will consider replacing. The ring I have the new ring ther so ima roll with it till it doesn’t work any longer and then put the new one most like in the future ima swap to a z21 I have a almost complet truck Quote Share this post Link to post
