1973 Datsun 620 Pick Up for sale
I am selling my 1973 Datsun 620 Pick up. It has a 4cyl 1600 with a 2bbl Weber carburetor. It has an electronic distributor, new clutch set,new water pump/fan clutch,new clutch master cylinder, new slave cylinder. Someone installed disc brakes on the truck before I bought it. The truck runs good and drives,but if you drive faster than 45 mph the bump steer gets bad. I am asking $1,200.00 the registration is good until Oct 2010. May consider a trade for a 510 or a 720. Call me at (916) 220-8620 I live in Sacramento Ca. I don't have a computer, but I can send pictures from my phone. Please call or text.
  • Replies 9
I spoke with an alignment guy. I told him the camber is noticeably off. One of the front wheels is angled in at the top. I told him when I drive the truck will go straight, if I apply the brakes it continues straight. So I know it's not brake related. When I increase drivng speed to above 40mph and hit a bump in the road the front end bounces and while driving the truck will shift positions in the lane. The alignment guy told me it was called bump steer. Maybe he was wrong? Anyone have any ideas?
The torsion bars are likely just sagging a bit, more on one side. These can be adjusted and will lift the truck to it's proper ride height. This will likely remove most of the excess camber. A badly worn king pin on that side could also cause it to lean in and add to the camber.
Before I got the truck someone put disc brakes on it. I believe it now has ball joints on the front. The rotors are solid. The control arms that are on it do not rest correctly on the bump stops. They appear to be too short,and are pulling both wheels inward at the top. I've read some of the forums,but I don't know exactly what steps I need to take to correct the problem. I really would like to fix it and be able to drive and enjoy the truck. Any thoughts or ideas would be appreciated.
