Get Garage!
RadioRedline
  • Replies 3.4k
Guest kamakazi620
lol stubborn ass radio.. i swear he joined here just to go against our grain :P
its ok tho cause he makes us laugh..
Makes us laugh??????? you do a FINE job at that!!!!!!! like a fram filter fanatic!!!!!
Sorry no pics, camera phone still in shop :( BUT I did FINALLY finish my carb for my yellow 620! I must say, its perfect, and beautiful! I will post pics asap. I set it on the manifold and will bolt up, hook up the vacuum lines, and throttle cable, and start her up! Also have my red 620 on jackstands and have the winterwheels off, so I can service the brakes, and powdercoat the rims properly, unlike spray it on the truck technique by the P.O. GRRR!
Radio
Can't wait to show you that Fram is fine.
Radio
Poor Radio ,
Many ratsuners have had bad luck or know people who have bad luck with cram.
Sure you can cut a filter open and show it's contents , ponder the marketing ploy, type of shipment to retail stores , or you can wait for it to starve/plug your engine up like it started to on mine. ( I got reallllllllly lucky ) If you don't believe anything else , know Fram = Engine Death. This is not a joke :no: :no: :no: . Yes I have used them in the past and had no serious problems , but better safe than sorry. ( There like cheap condoms , they don't work when you want them too ! and always do when you expect them not too :lol: :o )
:rofl: :rofl: :rofl: I have had a bad experience lately with the "sure grip" brand of "Cram Oil Filters." Please click link and continue further to read at least first post.
http://community.ratsun.net/topic/19380-fram-oil-filters-fail/page__view__findpost__p__269308__fromsearch__1
Will you do a trade in program ? I'll find/ship some Frams to you and you ship me back Wix/Napa/Purolator filters ??? :lol: :P :D
Waiting for pictures of the carb :D
Wow, we have gone full circle, if anyone cares to read the original, starts on page three goes for about 2 pages, then shows up again around page 17, and some where in the mid 20's too....yeah we get it Fram sux....ok...got that motor out yet???? :angry:
so i don't think i've read every single post, but i know i've read most. i just wanted to add my 2 cents on this fram argument. i work at a parts store. i sell those shitty filters all the time. i try to get people to buy better stuff... but they don't listen. that whole brand loyalty thing is really strong in the south. "my daddy always used frams and i'm gonna always use frams" whatever man. it is true that fram filters are not the best filters in general. it is also true that there is a difference between frams purchased at walmart and frams purchased from a parts store, or a tire store. (walmart does this with alot of their products, name branded chinese knockoffs.) that being said, their "good" filter from the parts store is still not the best filter available. even if you just "upgrade" to the fram tough guard it's a step in the right direction. for the average everyday knuckle head that buys them, it doesn't matter. for a fellow ratsuner i would suggest you look into the vast amounts of information available on here and other sites about filter quality and all that.
to end on some sort of a positive note. good job on the trucks, and as late as it is, the garage looks good.
now everybody can continue the completely necessary jabs.
Okay Gents. Want to get yellow running today ...need some assistance!
-Bolted carb on manifold. Check!
-Reattatched fuel line. Check!
-Charged up battery last night and hooked up cables. Check!
-reattatched throttle cable. Check!
Turn key in ignition, and I get one click, checked battery cables and their o.k. What am I missing?
Radio
Radio
Make sure you are getting 12v to starter solenoid w/cranking. If thats ok. Then tap on starter w/prybar w/cranking, if it cranks bad starter
I remeber this happening to my 620, it turned out to be the solenoid, I took the noid off, cleaned the plunger and inside where it slides, put it back on and wala. back on the road again.
Ran a jumper cable from positive on battery to starter directly. nothing happened. Checked battery connections, starter, solenoid connections, all look good. When I turn the key the guages light up once, and It goes 'click' once. So I will get starter tested tom I think. and get a new one if thats needed.
Radio
Radio
did you try jumping the connections on the starter with a screw driver, if that still just clicks then your starters out
Radio
You might want to make sure you get a warranty too if you can afford , Re-Manufactured starters and alternators are always a dime a dozen for me ( Try one , take it back , exchange , try another , take it back and exchange , try another , etc.... ) for a lot of electrical stuff like that. Stay away from Auto-Lite ( I always have bad luck , but could be wrong :lol: )
Yellow was back on the road last night! Cruzed all around Regina, took it for a bath, royal treatment! My Friend James came over to help getting it tuned and running. It seems to have an erratic idle, still but This morning it turned over, but couldn't get it started, and I flooded it after trying. So tonite will attempt to find out if its the choke not closing tight enuf (my 1st suspiscion) or maybe timing? Either way I am 1000% ahead of where I was!
Radio
