Need L16 crank pulley. Cheap!
  • Replies 6
either pulley will function correctly.
yes but you might not be able to use a timming light as the marks(notches) on the crank might be be aligneded to a L16 pointer or even anoth L20 that uses a a timmin plate on the passenger side. or the driver side.
I had 2 L20 blocks and @TDC the mark was on one side and the other l20 it was on the otherside.
whatever you use get the correct timming plate or pointer for that crank pulley.
