Ant-dat Posted November 19, 2009 Report Share Posted November 19, 2009 after such a ncie response on my 200B i thought i'd share my 180B with you guys, So here is my 1979 Datsun 180B (FJ20ET) restoration and build pictures (loads of pictures) Shell pictures Rebuild pictures Quote Link to comment
Ant-dat Posted November 19, 2009 Author Report Share Posted November 19, 2009 (edited) and some specs Body carnival red (pearlescent paint) JDM Spec wing mirrors Datsun 200B series 2 front grill, painted satin black and lower body colour Early style bumpers Clear front signal lamps Interior Standard 810 interior Sunny coupe (B310) steering wheel SSS dashboard Engine / Transmission Nissan Skyline (R30)/Gazelle(S12) FJ20ET (2.0 16V turbo) 8mm fuel fed line, standard as return Modified FJ distrubter to put out nissan 200sx (S14) signal Nissan 200sx (S13) acclerator cable and pedal Nissan 200sx (S13) coil packs modified to take a HT lead ad to connect to nissan 200sx (S14) loom modified Injector harness to take FJ injectors modified intake to take Nissan 200sx (S14) ACC/idle control valve Modified intake to take bigger throttle body from Primera GT Front mounted universal intercooler custom pipework FJ20 gearbox R160 Diff (at moment plans to upgrade to custom VLSD) Datsun Skyline (240KGT tank) Bosch fuel pump sard adjustable fuel pressure regulator with gauge Nissan Silvia (S12) radiator PAC cooling fan (ECU controlled) powder coated plenum and cam cover) greddy Typre RS dump valve Brakes / Suspension Nissan Skyline (R32) 4 pot alloy calipers Nissan 200sx (S14) 280mm brake discs Stock drums on rear (plans maybe to upgrader to disc brakes) Braked front brake lines large brake master cylinder custom coil overs all round Datsun 280zx rear ant roll bar Nissan 200sx (S14) drop links (polly bushed) Nissan Silvia (S12) front anti roll bar front Nissan 200sx (S13) drop links (polly bushed) Tein Camber plates Kyaba shocks 280lfb front springs 200lfb rear springs Polly front bushes stock rears All suspension components powder coated in gloss black 17" Rota D1 alloys Electrical Moddified S14 (200sx) engine harness Moddfified S14 ECU (Nistune completely programble via consult port) Consult port (diagnostic port) Greddy boost gauge Greddy profec II boost controller Air/fuel ration gauge SSS dash cluster Kenwood head unit @ speakers Battery relocated to boot (red top battery) custom body wiring (to relocate relay box from engine bay and hide as much wiring as possible) It's had a couple mag features which i still have to scan in, but when i do i'll post them up Edited November 19, 2009 by Ant-dat Quote Link to comment
Whoracle Posted November 19, 2009 Report Share Posted November 19, 2009 no seriously, your cars are so nice Quote Link to comment
stevensonDNL Posted November 19, 2009 Report Share Posted November 19, 2009 Ant-dat, that car is simply amazing. It's quite apparent that you've spent alot of time, research, planning and effort to acheive your goal! Definitely magazine worthy. Thanks for sharing. Dan Quote Link to comment
yellowdatsun Posted November 20, 2009 Report Share Posted November 20, 2009 Dang, that's even better than the other one. Quote Link to comment
HRH Posted November 20, 2009 Report Share Posted November 20, 2009 +1 for that, don't know if it's the paint or rims, or both. Dig it more than the blue one even though the blue one's quite nice. Quote Link to comment
Ant-dat Posted November 20, 2009 Author Report Share Posted November 20, 2009 thanks for the kind comments :) once the body was back from mates body shop it took me little over a year to built it, It's a bit of a hand full in the wet and we get a lot of rain. Planing a few changes over the winter if all goes well, maybe get the LSD in there and looking at maybe changing the front suspension over to S13 as i'm not quite 100% happy with what i have so far. Quote Link to comment
Ant-dat Posted January 13, 2012 Author Report Share Posted January 13, 2012 not updated this in ages, Not much has changed on the car but i did get soem time and finally get the boot (trunk) sorted. before After Quote Link to comment
ggzilla Posted January 13, 2012 Report Share Posted January 13, 2012 It's gorgeous. The wheels looks really superb with that red paint. Won't it be worse in the rain with the LSD, as it has enough power to spin both wheels? That's Datsun model series 810. Did the 180B come stock with the Z18 or Z18ET? Quote Link to comment
Ant-dat Posted January 13, 2012 Author Report Share Posted January 13, 2012 thanks for the comments, think at the moment it spins one wheel causing it to go sideways (with no effort lol) i was hoping that with power going to both wheels at same time it may help to keep it straight. I have built a R200VLSD for it but stuck on driveshafts as they look to cost more that buying a R160 LSD that i can use my stock driveshafts with. I also plan on changing the front suspension as i'm not 100% happy with it I also made a little build up video for it in the UK the 810 (180B) came with 2 engine choices L18s used in the 4 door and 5 door wagon L18T used in the 2 door coupe (180B SSS) we also got a 160B (810) and it came with a L16s Quote Link to comment
Ant-dat Posted January 13, 2012 Author Report Share Posted January 13, 2012 here are some more pictures of it, take during a photo shoot for a magazine I can scan in the mag features if you like to see them. There was 3 features in differnt magazines Quote Link to comment
ggzilla Posted January 13, 2012 Report Share Posted January 13, 2012 Wow, i think the short wheelbase 810 looks so much better. We only got the long-nose version here. Quote Link to comment
KC Phirus Posted January 13, 2012 Report Share Posted January 13, 2012 SO purty Diggin the colors IF Iron man drove a datto Quote Link to comment
Ant-dat Posted January 13, 2012 Author Report Share Posted January 13, 2012 Wow' date=' i think the short wheelbase 810 looks so much better. We only got the long-nose version here.[/quote'] I'd love a G810 , nice bay for a RB or something. Quote Link to comment
Ant-dat Posted January 13, 2012 Author Report Share Posted January 13, 2012 lol @ KC Phirus thats quite cool :) Quote Link to comment
fisch Posted January 13, 2012 Report Share Posted January 13, 2012 Amazing car! Great photos! Quote Link to comment
