hosestop@msn.com Posted June 29, 2016 Report Share Posted June 29, 2016 I also used a Acura one but you need to modify arm a little ,,really cheap 20 bucks at Napa. Quote Link to comment
derek72_521 Posted July 1, 2016 Report Share Posted July 1, 2016 I also used a Acura one but you need to modify arm a little ,,really cheap 20 bucks at Napa. Any part numbers and pictures of it done? Quote Link to comment
hosestop@msn.com Posted July 1, 2016 Report Share Posted July 1, 2016 Here it is 5/8 used a clamp to mount and we made stock cables work 91 integra maybe ?Had to file stock arm or dremel to fit Acura valve really want one with arm on it , the truth is out there .dog thief ! 2 Quote Link to comment
Lockleaf Posted July 2, 2016 Report Share Posted July 2, 2016 Here's two options I found at work (oreilly). Murray brand p/n 74624 Found in 93 Honda civic. Has 2 mounting screws built in to which you could mount a bracket. And heres another, Murray p/n 74644 Identical to above, except that the lever is mounted on the other side. Not sure which might be optimal. Found in 99 Toyota Tacoma. 3 Quote Link to comment
symbiot3 Posted September 9, 2016 Report Share Posted September 9, 2016 This is awesome, thank you for posting!!! I'll be doing this on my "Billy Goat" in the coming days. Quote Link to comment
Goemon Posted April 30, 2020 Report Share Posted April 30, 2020 My 620 is steel, corroded and No Longer Available. I found one that is almost the same from anothe car. I will know if it is correct when they get here in a few weeks. L shaped, cable control, pull to close. Quote Link to comment
datzenmike Posted April 30, 2020 Report Share Posted April 30, 2020 One of the 720s ises a plastic 'in line' control valve. The hoses are stiff enough to hold it still for the pull cable... Quote Link to comment
Goemon Posted May 2, 2020 Report Share Posted May 2, 2020 This one should work, but it is pricyhttps://www.ebay.com/itm/New-Heating-Valve-Vauxhall-Kadett-B-Olympia-a-Gt-Manta-Ascona-Heater-Control/264143326269?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D225086%26meid%3Ddd70ee4d4bb84b15ad456fadcd048cf8%26pid%3D100290%26rk%3D2%26rkt%3D4%26sd%3D312731128523%26itm%3D264143326269%26pmt%3D0%26noa%3D1%26pg%3D2060778&_trksid=p2060778.c100290.m3507 Quote Link to comment
Crashtd420 Posted May 7, 2020 Report Share Posted May 7, 2020 Nissan part.... Available here... https://nissangenuine.com/nissan/nissan-cock-heater-27017b5000/ Quote Link to comment
Goemon Posted June 6, 2020 Report Share Posted June 6, 2020 (edited) That link is no good. I paid for one a month or so ago and they reimbursed me. I've been waiting on these for well over a month, so now I don't need one. I got chewed out for putting the link above up because someone thought I was making a duplicate post. It had nothing to do with the other post so fuck it.......... Edited June 21, 2020 by Goemon I fucking wanted to Quote Link to comment
Goemon Posted August 18, 2020 Report Share Posted August 18, 2020 5 left and then they are gone and all the info for the rest in the world is in another post here somewhere. They will accept the Datsun / Nissan cable clip Come with extra rear seal orings $55.00 shipped inside U.S. $67.00 to AU Quote Link to comment
Draker Posted August 19, 2020 Report Share Posted August 19, 2020 Got mine and I don't own a 620.. yet. Quote Link to comment
russaroll Posted July 14, 2021 Report Share Posted July 14, 2021 (edited) Some good info up in here. This http://www.510coop.com/heater/ is the write up I used to rebuild my heater. I think the part # he lists is NLA but i found that works just as good. It's almost identical to the one Crashthd420 posted. As you can see the guts are exactly the same. On a side note. Anybody know what the 2 pieces that pass through the fire wall are or where i could get a set? Edited July 14, 2021 by russaroll 1 Quote Link to comment
