sycloned916 Posted January 7, 2010 Report Share Posted January 7, 2010 are you using stock turbo and wastegate? Thanks Jeremy No I have a different one,so you might need the boost sensor. Looking at my harness its hard to tell I shortened it up so much and got rid of a lot. My other motor should be here by Friday and I'll take some pic's of what the three plugs used. Quote Link to comment
jeremy_sr510 Posted January 8, 2010 Author Report Share Posted January 8, 2010 ok I'm starting to get it.... more questions... since i don't have a booster do i just plug this? now back to wires... these would be the main 3 i need, that go along with the relays/diagram? close up.. other one... another.. is this one on the right for the tach? don't use the other one? then from the alt, oil pressure, starter, trans..... close ups... not sure what to do with them.... Quote Link to comment
sycloned916 Posted January 8, 2010 Report Share Posted January 8, 2010 I just put a AN plug there. The wires I just cut the plugs off them and pulled the ones needed the rest I taped and shortened away to keep the harness kinda nice and neat. There will be other plugs not used some I did the same shortened and tucked away with tape. The tach wire is I think off the white plug next to the ecu plug still have not done mine yet, I have a aftermarket tach and think I have to use a tach adapt from autometer. The alt I have a 110amp one wire on mine,I'll find were I saw how to hook it up,I'm gonna need to do the same for my 510. I used the orignal starter wire from the 520 for the starter. You'll have afew extra plugs not used don't worry as long as you stay on track with the diagram is gonna run. Quote Link to comment
jeremy_sr510 Posted January 9, 2010 Author Report Share Posted January 9, 2010 so any one else know how i wire up the alternator? Quote Link to comment
Icehouse Posted March 18, 2010 Report Share Posted March 18, 2010 Pull back the sheilding on the plug for the alt, snap pic of it on the alt with all connects in the pic and I will draw some lines and stuff on it. :) Quote Link to comment
jeremy_sr510 Posted April 12, 2010 Author Report Share Posted April 12, 2010 well i have been busy working on it and slacking on the site..... all i need now is my aliment. took it to town and back worked great besides a brake problem (think i fixed it yesterday) and i need a tach adapter to get that working correct... some pics more to come soon. Quote Link to comment
bonvo Posted April 13, 2010 Report Share Posted April 13, 2010 that intercooler posisstion looks like crap in my popinion but other then that it looks good Quote Link to comment
jeremy_sr510 Posted May 23, 2010 Author Report Share Posted May 23, 2010 car has been going for a couple weeks now couple pics from the track ill get more under the hood soon.... Quote Link to comment
