pnut90 Posted April 20, 2013 Report Share Posted April 20, 2013 How much shipping to 94521..:-) Link to comment
deans510 Posted April 20, 2013 Report Share Posted April 20, 2013 How much shipping to 94521..:-) You must be in Concord as my zip is 94519. Give me a call 925-685-3423 Link to comment
Dzaster Posted May 5, 2013 Report Share Posted May 5, 2013 Wondering what is the difference between the earlier and later years of 280ZX that jesusno2 brackets require the later year brakes? I was told my brakes were pulled from a 82-83 280ZX but I don't know that for sure. Can anyone confirm this? Also, anyone who's installed the jesusno2 rear disk setup on a goon, have they ran into any problems. My problem is the the rotor rubs the inside of the caliper and does not sit right. However, I think I see this in jesus's picture as well. I'll try to explain. When I refer to upper, its the side of the caliper that is closer to the fender well and lower is in reference to side of caliper closer to ground. Installed: Upper rotor caliper inside clearance: Lower clearence: Upper side of caliper mounts farther away from outer edge of rotor: Lower side sitting right on outer edge of rotor and actually rubs. My previous drum setup had some shims between backing plate and axle flange. When i first mounted the brackets I had those shims in place as I thought it was for axle bearing spacing/relief. However, inside caliper and rotor was rubbing even worse. I then removed the shims and was little better, but is what you see in pics above. I also tried switching using the right side rotor on the left and is seems to clear a little better, but I can't see how that could be. I also didn't toque everything down so that could change. Do I perhaps have wrong year brakes or am I missing something in the install process? Any help much appreciated. I may be able to edit the bracket and mounting config to get things straight, but before I start carving into stuff be good to know if I'm doing something wrong. Link to comment
deans510 Posted May 5, 2013 Report Share Posted May 5, 2013 I still have these brackets for sale, goon & sedan. I'm posting on this thread because the originator stated that he was out of stock and wasn't going to make any more. Link to comment
deans510 Posted May 5, 2013 Report Share Posted May 5, 2013 Corrected the pic for the sedan brackets. Dean Link to comment
Dzaster Posted May 5, 2013 Report Share Posted May 5, 2013 Thanks Dean. I need to see if I can work this out before I decide on scrapping this setup and going with yours since I have about $300 into these now and would be looking at $300 to complete yours. What range of years 200SX calipers for your brackets? And I think in your article you mentioned the 200SX and 280ZX used same rotors, or did just make that up? lol I can use the ZX cables and lever? I think its just banjo lines, 200sx calipers and your brackets from what I have--which are all 280ZX parts. Link to comment
